Originally posted by dales I go to the Menu, Raw-DNG, select, o.k., than Menu to exit than when I ck the 'info' screen it shows that it did not change to raw but is still JPEG. Also the pics. available to take remains @ the JPEG quantity. I have tried double clicking the o.k. button twice but this makes no difference. I have also tried to change by selecting the 'RAW' button on the body but this does not work either. What am I doing wrong? I would like to start working in RAW. Thanks for the help.
The RAW button on the body will only work for the next shot, then cancel, by default. You can set it to toggle RAW on/off in the menus.
When you go in the Rec. Mode menu you must set your options on the first two lines on the second page of the Rec. Mode menu. In short hand:
[Menu]
[V] 7 times to select [File Format]
[>] and [^]/[V] to select either RAW or RAW+ (which also does a jpeg)
[OK] to select this format
[V] to select [RAW file format]
[>] Select PEF or DNG
[OK] to select your option
[OK] or [Menu] to exit.
If you want to retain this as your standard setting when you set the mode dial to [USER], you also need to go into the Set Up menu and save the settings.
[Menu]
[Set Up Menu]
[>] on [USER]
[OK] to save the settings to your [USER] mode.
Hope this helps!
