Originally posted by Neel1 When I asked the seller, he told me that I can't use the Tamron 28-77 mm F2.8 at wide angle on my Pentax K200D....Is that so? I mean why is that so? Do you think it's still worth acquiring for my Pentax K200D?
28mm is not very wide on a digital SLR because the sensor is smaller than the 35mm film size that the lens was designed for, so there's no sensor at the edge of the image circle to collect the light. It's an equivalent of 42mm, which is close to a "normal" focal length on digital.
As I recommended earlier, if you want proper wide angle, look for the Tamron 17-50mm, f/2.8 instead. It should cost about the same and will be a better all-round focal length range. It's an excellent lens.
