01-21-2012, 02:55 AM   #1
Just bought K10D, line across every picture
like the title says, i just bought a K10D on ebay, it looked like it was in great shape, obviously well cared for and with only 2900 shutter actuations. i was taking a few pictures just to figure out how to use it and threw a bracketed set into photomatix. i noticed a yellow line in the lower left of the photo, going almost to the center. In the HDR photo, the line really pops and is very obvious. i reviewed the originals and sure enough every single one has that line in exactly the same spot. there is also vertical streaking, and 14 dead pixels. i expected to see a dead pixel to two, but 14? i've attached two photos, the black one is a picture at 1600 iso with the lens cap on, it shows the 14 dead pixels and the horizontal streak. the picture of the fan shows the vertical streaking and the horizontal line. whats going on with this camera?
01-21-2012, 03:27 AM   #2
Welcome to the forum.
Some hot pixels isn't surprising, but streaking like that shouldn't happen. It looks like a sensor issue, probably not worth repairing on a K10D. I'd recommend you attempt to return it as defective. If the seller is uncooperative, you should have some recourse by disputing it as not being as described, but you should give the seller a chance to accept a return and refund it first.
01-21-2012, 09:19 AM   #3
Greeneg's Avatar
That's a failed or failing sensor line. I have had two of these go on my K20D ( fortunately I had the extended warranty and it was covered both times) and that line is not a good thing. It can occur both horizontal and vertically.
Only cure is to replace the sensor.
camera, dslr, k10d, line, photo, photography, picture, pixels
green line and red line on lens dh4412 Troubleshooting and Beginner Help 3 03-28-2011 11:39 AM
Picture I Couldn't Take w/my K10D joelovotti Pentax K-5 & K-5 II 14 12-27-2010 05:04 PM
With all of this talk of K-5, I actually bought a K10D new... sjwaldron Pentax K-5 & K-5 II 38 11-03-2010 12:50 PM
Setting Picture Line on K10D dcp5570 Pentax DSLR Discussion 2 09-06-2007 09:15 PM
K10D Images on Line benjikan Pentax DSLR Discussion 13 03-02-2007 10:14 AM
All times are GMT -7. The time now is 01:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
