Originally posted by myrdinn That's the question. Will the old lenses - produced for analog films with a limited resolution of 16 million pixels - still be good enough for the newest generations of camera's?
All lenses are different ! Its down to the individual lens here. The old 50mm f1.4 has been replace with the new 55mm f1.4
The older lens doesnt perform as good as the new one, when used wide open, but shut down a couple of stops there is not much difference.
But.... its not just about resolution..... the old 50mm suffers far more purple fringing etc.
Im sure some of the old lenses would still be very capable but there will be many that are not.
A lot depends on the design of the lens rather than the quality of the original build. Pentax do a really cheap 35mm f2.4 for example.
Its as cheap as chips.... but the design is perfect, and produces some of the best results available at any price at this focal lengh.
Its also worthy to mention the fact that the old lenses designed for 35mm have a bit of an auto uplift on the original use on 35mm
simply because when used on apsc you tend to get the sweet spot of centre lens performance.
Reason: added info
