12-31-2007, 04:20 PM   #1
Kaelyn84's Avatar
Another 285HV Question........
Ok,
I already have a Vivitar 283, that I can't use on my K10, I am going to buy a 285HV to use on camera, but can I fire them at the same time? And if so what will I need to do that? I would also like the freedom of using the 285 off camera, what would I need, to be wireless? Lots of questions.....
Thanks,
Kaelyn
01-01-2008, 12:47 PM   #2
Yes, you can do one of two things: hotshoe to sync port (you need an adapter for your Vivitar flash) and then a sync splitter (looks like a Y cable).
Or get the fleabay triggers (search for "v2s trigger" on fleabay)...
01-01-2008, 01:39 PM   #3
Be careful, even when connected by a wire the old 283 can still damage the circuit in the 10D. I use my old 283 ( and other older flashes) with my K10D by using a Wein Safe Sync adapter. It is a hotshoe adapter that will safefly reduce any trigger voltage, up to 400v, on a flash to a safe 6 volts. Can be used to mount a flash on the camera or used with a cable. It costs about 50-60 dollars but it allows me to use all my old flashes safely.
01-01-2008, 02:53 PM   #4
Kaelyn84's Avatar
Thanks for the replys!
01-01-2008, 05:55 PM   #5
Mike Cash's Avatar
Didn't we already answer this exact same post in another subforum?
Would you like to click over there and read the answers? Or should I copy-n-paste them into this thread?
01-03-2008, 08:34 PM   #6
As others have said, the 283 can't be connected safely to the Pentax. The 285HV can.
I'd suggest:
Use the 285HV triggered either:
On Camera
Off-Camera Wired (Using any number of a variety of adapters - I use a hotshoe-to-PC cord and a PC-to-hotshoe adapter)
Off-Camera Wireless (either the "eBay triggers" or Pocket Wizards)
And use the 283 triggered with an optical slave of some sort. (i.e. triggered by the 285HV's output)
camera, dslr, photography
Vivitar 285HV oldjohn Pentax Camera and Field Accessories 3 04-21-2010 05:37 AM
Vivitar 285HV Question... spun Pentax Camera and Field Accessories 6 01-31-2009 05:59 PM
Vivitar 285hv Charles1 Pentax Camera and Field Accessories 9 12-05-2008 01:48 PM
Vivitar 285hv owners. Power save question. Peter Zack Pentax Camera and Field Accessories 13 08-16-2008 06:01 AM
285HV Question Kaelyn84 Pentax Camera and Field Accessories 15 01-07-2008 05:37 AM
All times are GMT -7. The time now is 04:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
