01-01-2008, 09:51 AM   #1
fwbigd's Avatar
Studio Flash Sync Speed for K10D
Recently, I noticed that my K10D was casting a shadow on the bottom of the image when using the X (1/180th of a second) setting with Studio Flashes and Pocket Wizards to trigger them. If I switch the camera to the manual mode and reduce the speed to 1/160th of a second the shadow begins to lesson. The shadow is completely gone at 1/125 of a second.
I went back through my file and the problem began to appear about three months ago. Has anyone else experienced this problem?
01-01-2008, 09:54 AM   #2
Duck Dodgers's Avatar
Someone said that the RF triggers will do that as their batteries get low. HTH.
01-01-2008, 12:37 PM   #3
stewart_photo's Avatar
To insure the camera syncs properly with these overall slower flash units, the recommended sync speed with studio flash units is 1/100 - 1/125s. This is vaguely mentioned in the owners manual, but certainly not clearly. I guess they assume studio photographers will know this on their own - or discover it as you have.
stewart
01-01-2008, 12:42 PM   #4
QuoteOriginally posted by Duck Dodgers Quote
I've never been able to sync higher than 1/125 with PWs and Impact Monoblocks (B&H private label, I believe built by Bowens) or my Sigma 500 DG Super and Vivitar 285hv combo. In my studio, I have not run into a problem, in the field it could effect shots where I want to control the BG with the shutter speed.
I don't know if the problem is the camera, or the PWs, but it is a bit aggravating.
camera, dslr, k10d, photography, shadow, studio
Is Flash Sync Speed limited by the body or flash? Reportage Troubleshooting and Beginner Help 16 09-16-2010 06:18 AM
Discuss: Hack/enable a higher speed sync flash K10D imadethis Pentax DSLR Discussion 19 05-06-2009 04:57 AM
Flash high speed sync. Deni Photographic Technique 22 08-26-2008 02:35 PM
Maximum flash sync speed jshurak Flashes, Lighting, and Studio 19 12-05-2007 12:13 PM
K100D flash sync speed Tyler Pentax DSLR Discussion 2 04-27-2007 12:08 PM
All times are GMT -7. The time now is 12:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
