02-07-2012, 07:31 AM   #1
second hand DA35mm-F2.4 sticky dirty
Dear All:
I just got the used pentax DA35mm F2.4 with 193USD from the local HK pentax user.
It was my fault that i didn't get careful examination at MTR station where we trade.
After back to home , it is found that there is sticky dirty on the plastic of len but it does not affect the image of photo.
I made phone call to the original owner and he said he didn't know what happen and it had been covered by UV filter long time.
He was obviously telling lie.
Do anyone know what happen to the lens ?
there are problem linking photo to the forum, please go to below for viewing the photo
http://www.potuker.com/photoview.php?id=3f85d7f3a3f50394bd5f11b2c4a13a85
\r\n\r\n\r\n
02-07-2012, 07:48 AM   #2
Add a pic to show us!
02-07-2012, 07:55 AM   #3
JFN
JFN's Avatar
Smoker?
02-07-2012, 08:05 AM   #4
Try a cotton bud moist (not dripping wet) with alcohol to clean it.
02-07-2012, 08:09 AM   #5
QuoteOriginally posted by gp1806 Quote
have tried but difficult to get rid of all
02-07-2012, 08:09 AM   #6
Docrwm's Avatar
The photo keeps hanging my computer up. Try loading it directly from your computer to the Forum via the "Go Advanced" and then "Manage Attachments" buttons.
02-07-2012, 08:27 AM - 1 Like   #7
philippe's Avatar
Try WD-40 but be careful not to use to much, it's better to rub twice with a little bit of that product than wanting to clean all at once. Do not touch the lens with WD-40, you never know.
If, after that WD-40 treatment, the plastic seems somewhat 'dry', then rub it with some Ballistol (German gun oil), it will look nice again and this product conserves synthetic materials too.
Alcohol is not that wise because the lens elements are cemented wit a product that might solve in alcohol.
02-07-2012, 10:51 AM   #8
QuoteOriginally posted by philippe Quote
Yes! This will dissolve adhesive but use carefully and with caution...
02-07-2012, 01:30 PM   #9
Docrwm's Avatar
I could be wrong but, now that the picture loads, it looks as if a plate is missing from the lens. That would explain the sticky substance uniformly around the circumference of the front of the lens.
02-07-2012, 01:32 PM   #10
Take a sturdy lint-free cloth, wet it with naptha (lighter fluid) and gently scrub the rubber part of the lens grip. Another solvent that is more environmentally friendly is citrus based solvents, these are excellent degreasers good for removing sticky price tag residue. Again, wet the cloth enough to feel damp but not enough to drip.
02-10-2012, 10:19 AM   #11
QuoteOriginally posted by Docrwm Quote
but why don't you have this sticky dirty? how long have you used this your DA35mm?
02-12-2012, 06:49 AM   #12
Docrwm is onto it. The stickydirty is double-sided adhesive used to hold a (now missing) plate in place. It may be possible to source a replacement plate from Pentax to bring it back to its original appearance. The seller is a chancer!
BFN
David
02-13-2012, 03:19 PM   #13
DaveHolmes's Avatar
It's an adhesive (glue) and you have a ring/spacer/plate/something missing...
You got stung...
02-13-2012, 04:15 PM   #14
wlachan's Avatar
Looks like the seller was trying to disassemble the lens and destroyed the tape on ring. Maybe you can try to contact Pentax Japan directly for a replacement part which should be very cheap since the HK distributor will just rip you off.
02-16-2012, 05:09 AM   #15
yes , you are right. I am not familiar with lens construction . Now i got stung.
camera, dslr, pentax, photo, photography
a new lens <DA35mm F2.4 AL> on the K7 jay790 Pentax SLR Lens Discussion 17 11-05-2010 01:29 AM
Already own DA35mm. Keep FA50mm f1.4? raider Pentax SLR Lens Discussion 14 08-30-2010 12:45 PM
Suggestion Dirty Sensor Sticky JeffJS Site Suggestions and Help 3 08-02-2010 07:17 AM
Dirty Sensor Or Dirty Lens? Orli Troubleshooting and Beginner Help 8 10-26-2009 03:35 AM
All times are GMT -7. The time now is 08:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
