-"Apsc lenses *are* wider"
True...nothing like the sigma 8-16 in a nikon FF setup.
Lense wise FF and APSc are different,especially in the wider area, since it's not only a field of view question but also a perspective question. In apsc "equivalent" FOV lenses have their own focal length perspective...that's why when someone tells you that a 50mm is equivalent to a 70ish milimiter lens he's only talking about FOV and therefore he's being misleading...a 50mm lens is a 50mm lens. FF enables you to use the wider lenses with a larger FOV than APS-c wich can be a plus for some people and some types of photography. For some applications i may want the field of view a sigma 8-16 delivers on an aps-c but without such an exagerate perspective (for others i may want my 8-16 precisely because of that
FF has advantages over APS-c in the resolution,ISO and noise areas wich can mean a lot for someone who works in some fields of photography...but for the vast majority and for the most common usages the apsc cameras that exist today are appropriate (in the case of the higher end ones one could argue they are overkill).
Now personally...i need a FF camera, for two simple reasons: customer expectations and industry standarts. I've started to work as a photographer and although i've been producing decent material with my beloved Kx, i've started to meet new potential customers that need to feel they are hiring a pro...that means that besides the suitable material i need to "look" like a pro, at least like an uneducated in photography gear person sees them: big FF camera systems, and preferably Canikon
Once you get known and your name has some prestige you can shoot whatever you like (but then, at that moment, i'm sure you can afford a medium format setup for the studio and a couple of FF for the events
Of course since i'm expected to have Pro FF setup, and since i'm gonna buy one i'm gonna profit from the bigger pixels and/or a hefty increase in resolution...i'm gonna love the shallower depth of field and the bigger FOV.
