Originally posted by Laurentiu Cristofor I am confused by this statement. On a 100MP APS-C sensor, diffraction would take effect from around f/4 (I used an
online diffraction calculator). So how is diffraction not an issue up to 100MP? We already get diffraction above f/8 with 15MP sensors.
I talked about diffraction
limits, not diffraction
effects.
The full treatment of the issue is complicated. Because it must consider lens blur due to aberration and lens blur due to diffraction.
For the
very best lenses along the optical axis, the resolution limit (~MTF10) is about 150 lp/mm times F-stop (according to my own research) and the latter is about 1500 lp/mm divided by F-stop (Rayleigh criterion). The combined resolution maxes at F-stop 3.2 sqrt(1500/150) with a combined resolution of ~333 lp/mm.
As you can see, the diffraction limit for FF is around 7.8 billion pixels (3.3 billion for APSC) and "far beyond 100 MP" was a mild way to say just this. Moreover, the
very best lenses can resolve a 380 million pixel sensor in the center (160 APSC). I have actually seen this with my own eyes, using a special high resolution B&W film with a DA70 and inspecting the result under a microscope. But don't be mistaken ... there is so much blur from other sources you will almost never touch into this high resolution regime with your photography, even if lens and sensor would allow so.
Eventually, there are only
very few lenses with so little aberrations. Measurements in the photozone style can only indirectly identify them, by measuring the F-stop of highest resolution. These very few lenses have it at f/2.8 rather than f/4 (f/5.6 is a more typical point of max. resolution). One such lens is the Nikkor AF-S 200mm f/2 G ED VR (FX) photozone test which resolves best at f/2.8 with 4076 LW/PH in the center on a 4000 LW sensor. This is spectacular as all other such lenses are shorter than 50mm. But this 200/2 is seven times the price of a DA*200/2.8 ...
But the Nikkor 200/2G + Pentax Q may be the most powerful combination wrt resolution reach below astronomical scopes ... because it even outresolves pixels as small as the ones in the Q.
Below this point, the answer will depend:
- Which lens?
- Which F-stop?
- How far off center?
- How exact focus?
- How much shake?
- What ISO?
If you always want full sensor resolution, I'd say the initial *istD (6MP) was already a bit over the top
