01-05-2008, 04:24 PM   #1
Menu Screen on K10D
Help.. this is frustrating, this camera is 2 months.
When I push the menu button, the menu screen comes on and then turns its self off, without giving me a chance to do anything. Today is the first time this has happened.
Has this happen to anyone else.
Or is it that I have a lemon as I have had the main board changed, as the hotshoe wouldn't fire external flashes.
IF SO THEN MAYBE ITS NOW TIME TO CHANGE BRANDS......I get enough crap from Canon users at race tracks about Pentax poor build.
01-05-2008, 04:29 PM   #2
Rickster's Avatar
Make sure you are not accidentally hitting the menu button twice. Try pushing the menu button about 20 times in a row to see if there is an intermittent switch. Sometimes cycling it a bunch of times will clean the contact.
01-05-2008, 04:36 PM   #3
Thanks, our IT guy said the same thing.
It just won't stay on.
01-05-2008, 04:39 PM   #4
Canada_Rockies's Avatar
Turn off the battery grip. Your little finger is hitting the shutter release on the grip. Very annoying. I know. Boy, do I know. I did it again today ...
01-05-2008, 04:46 PM   #5
I know what you mean, however its not ON.
01-05-2008, 05:29 PM   #6
jfdavis58's Avatar
The LCD goes out whenever one (or more) buttons is depressed--any of several buttons. Start with removing the battery grip and checking to see that all the buttons depress and return to the 'up' position. It will also go out if the lens is not properly mounted; remove and/or remount. Low batteries will also cause a failure-recharge. Try the menu button again and if the camera responds correctly, perform a system reset.
01-05-2008, 05:35 PM   #7
Are you using an after market lens? My 100D did the same thing until I switched to a Tamron lens and the problem was fixed. I posted this problem months ago. Good luck.
01-07-2008, 04:56 PM   #8
They now have the camera, I will let you know when its returned.
thanks to everyone.
01-07-2008, 05:03 PM   #9
When my sigma first arrived I had this problem, i had it upgraded and no more problems.
02-03-2008, 05:33 PM   #10
Well the camera came back, with they couldn't find a problem. Hmmm
I was out over the weekend at A1GP, and guess what it happened again.
One of the other photographers a Nikon user, had me change lenses from Sigma EX 28-70 f2.8 to 10-20 EX DC and 50-500 EX APO and the problem went away. He mentioned that Sigma has to re-chip the lens to suit the K10D without cost. I have had the 50-500 longer than the 28-70.
Has anyone heard about this, I have had my Sigma flash unit re-chipped.
02-04-2008, 02:58 AM   #11
Russell, I recall seeing numerous posts in the lens forum about Sigma lens re-chipping. Seems to be a fairly common procedure needed by many Sigma-using Pentaxians.
02-04-2008, 06:59 PM   #12
Well they now have the lens for re-chipping..
thanks
02-04-2008, 07:12 PM   #13
Busiko
Guest
QuoteOriginally posted by RussellW Quote
thanks
And what about the external flashes? Are they firing now?
Rui
camera, dslr, menu, menu screen, photography, screen, time
K10D Service Menu and AF Adjust! nosnoop Pentax DSLR Discussion 55 03-29-2019 10:23 AM
K10d - Menu Problems... mrchris Pentax DSLR Discussion 5 12-26-2009 02:52 PM
K10D Crashing when changing options in menu? jmdeegan Pentax DSLR Discussion 20 07-14-2008 08:34 AM
K10d-debug menu-IR possible? Bokeh Pentax DSLR Discussion 6 05-17-2008 05:54 PM
K10D Menu Typos Faither Pentax DSLR Discussion 13 12-02-2006 10:28 PM
All times are GMT -7. The time now is 11:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
