03-01-2012, 07:59 AM   #1
K-x AF "debug menu" calibration methodology question
Hey all.
In the interest of getting the absolute sharpest possible images from my K-x bodies, I'm planning on calibrating the AF through the debug menu. Here's what I'm wondering: Would it be better to use an AF lens at it's widest aperture (f3.5) & autofocus for the test, OR would it be better to use a fast manual focus f1.4 50mm lens at it's widest aperture (for the narrowest possible DOF and theoretically the most accuracy) and calibrate via the focus confirmation?
I'm guessing the focus confirmation/catch in focus is triggered by the same mechanism that is responsible for autofocus.
So, whaddya think?
Cheers,
Bobbo :-)
03-01-2012, 08:37 AM   #2
ironlionzion's Avatar
You'll need to calibrate every lens that is focusing off. On my K-x, my DA55-300 is perfect but my Tamron 17-50 is way off. Unfortunately with the K-x, you'll need to make a mental note of each setting and remember to change the calibration when you swap lenses. Having the camera recognize the calibration settings for each lens is a big benefit of the K-5.
03-01-2012, 12:23 PM   #3
kiwi_jono's Avatar
There is only 1 setting but changing the setting with lens changes would be too fiddly for me. I think you would be better to choose the lens that has the shallowest depth of field - that you regularly use. For me I ended up with a setting that is a bit of a compromise between my the lenses I regularly use (which changes from time to time).
In my case I'm currently using Super Tak 50 1.4, Sigma 17-70 and FA100 f2.8 macro the most. I tweaked it for the 50 f1.4, even though the close focus of the FA100 challenges DOF more because I mostly visually (or LV) focus for the macro, where as I rely on Focus indicator more for the Tak.
03-01-2012, 02:52 PM   #4
As it turns out, it's pretty much on the nose with both bodies, so I think I'm good. I'm just never satisfied til I tweak everything just so.
af, aperture, autofocus, camera, dslr, focus, k-x, lens, photography
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
Just bought used K-m, displays "DEBUG MODE"? skid2964 Pentax DSLR Discussion 2 12-15-2011 06:03 AM
Focus screen "stock" replacement - Calibration? kidblue Pentax DSLR Discussion 10 07-16-2011 02:25 PM
Question about "Battery Type" Menu Option on K-x mblanc Troubleshooting and Beginner Help 5 03-14-2011 06:43 AM
Best "k-7" menu settings Fl_Gulfer Pentax DSLR Discussion 5 04-15-2010 11:05 PM
All times are GMT -7. The time now is 05:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
