03-03-2012, 03:34 AM   #1
Using pop-up flash + external
If anything is mount on the hot shoe, the on board flash will not pop up fully -- precluding it from being used as an on axis fill.
I have a radio transmitter and a hot shoe extender; neither of these allow enough room for the on board flash to lift all the way up.
Does anyone know of a device that has a low profile that will let the on board flash pop up fully?
03-03-2012, 09:08 AM   #2
manacho2005's Avatar
If you're using a K5, you could utilize the pc socket. If not, I would recommend a wireless flash, and use the flip up as a master.
03-03-2012, 12:15 PM   #3
You could start with this:
New SC-2 Flash Hot Shoe Adapter for Canon Nikon Pentax | eBay
You may need to mod it if it's not tall enough, but it's just a little plastic box. Add plastic in between the two halves to make it taller. The wireless transmitter is very light and doesn't add much stress to the shoe.
board, camera, dslr, flash, photography, pop, pop-up flash, shoe
K20D pop-up flash doesn't pop up! ducdao Pentax DSLR Discussion 3 11-29-2011 07:57 AM
repair internal flash or buy an external flash Capslock118 Pentax DSLR Discussion 11 11-23-2011 05:22 PM
k5 pop-up flash hook (that holds the flash down) broken... Thesorus Troubleshooting and Beginner Help 4 01-06-2011 08:34 PM
K7 pop up flash @#%! ordinaryimages Pentax DSLR Discussion 12 04-05-2010 02:55 PM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
All times are GMT -7. The time now is 01:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
