03-05-2012, 09:24 AM   #1
klopus's Avatar
K10 - why Shake Reduction menu is greyed out?
I haven't delved deep into my K10 menus for some time and noticed that Shake Reduction menu item at the bottom of the Rec menu is greyed out and inaccessible. That's independent of the position of the SR switch on the back of the camera and independent of the shooting mode. It happens with all lenses - Sigma 17-70 2.8-4.5 (non OIS), DA 55-200 and DA 50 1.4.
I vaguely remember this menu being accessible. Is there something to worry about?
03-05-2012, 09:36 AM   #2
That option should only be accessible if you are using a lens that does not communicate focal length to the camera, which all 3 of your lenses do.
03-05-2012, 09:46 AM   #3
klopus's Avatar
Oh, thanks, that explains it. I have some old glass and now I remember entering focal length into this menu.
03-05-2012, 09:50 AM   #4
Actually a pet peeve of mine -- if you use a teleconverter that passes through lens info then it picks up the lens reported focal length instead of the actual longer one you're now getting, which means you have to turn off the SR which you really would want at the longer length (and the focal length is wrongly reported on your images). We should be able to override and set focal length for any lens...
03-05-2012, 11:41 PM   #5
I don't see why Pentax couldn't make a TC that automatically multiplies the focal length and sends that to the camera.
camera, da, dslr, k10, menu, photography, reduction
Shake Reduction on or off? GoldenRGuy Pentax DSLR Discussion 7 02-16-2011 08:37 PM
When to use Shake Reduction? Todd Adamson Troubleshooting and Beginner Help 9 11-04-2010 05:36 AM
Do you always have shake reduction ON? gawan Photographic Technique 18 08-01-2010 02:36 PM
Shake Reduction hannsg Troubleshooting and Beginner Help 5 06-11-2010 03:45 PM
K10 Pan with Shake Reduction on? joelovotti Pentax DSLR Discussion 16 06-17-2007 06:57 PM
All times are GMT -7. The time now is 03:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
