03-09-2012, 10:42 AM   #1
Manual white balance
Just a quick question. After manually setting the white balance in my Pentax K-x (using a gray card), and then taking the shot, does the setting stay put for subsequent shots as well? Or do I have to constantly reset it using my gray card for each and every shot? Or if the manual setting does remain constant for multiple shots, how do I get out of it when I am done shooting and wish, for example, to return to AWB.
I am just now beginning to experiment with manually setting the white balance for various shots. Although the manual explains how to set the manual white balance, it's not really clear on what happens with the custom setting immediately afterwards for subsequent shots. Thanks.
03-09-2012, 10:58 AM   #2
Marc Sabatella's Avatar
It stays set until you change it. Which is as it should be - the light presumably is not changing from shot to shot, so nor should the camera. The way you change it is by simply selecting another WB option - going back to AWB.
03-09-2012, 11:10 AM   #3
Excellent. Thanks Marc for the quick reply.
balance, camera, card, dslr, photography, shot, shots
Frustrated with KX Manual White Balance for IR... Internetpilot Pentax DSLR Discussion 5 06-15-2010 01:30 PM
Manual Focus + white balance yusuf Pentax DSLR Discussion 6 04-25-2010 09:55 AM
Manual white balance problem with K20D. DJP Pentax DSLR Discussion 2 11-01-2008 02:39 AM
Manual White Balance Question... PaulAndAPentax Photographic Technique 3 12-24-2007 04:27 AM
Manual White Balance Flaco Pentax DSLR Discussion 11 01-02-2007 04:19 PM
All times are GMT -7. The time now is 03:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
