03-15-2012, 03:52 AM   #1
gordon_l34's Avatar
Extension Tubes on K20D
Hi,
When I use an extension tube on my K20 with my Vivitar 105 and the camera asks me the focal length, do I leave the setting at 100mm which is the closest that I can get to 105mm or should I add in the actual length of the tube?
Regards.
03-15-2012, 04:15 AM   #2
Twarp's Avatar
It is to approximate the most optimal setting for the Shake Reduction so you should give the total focal length (lens + tube).
03-15-2012, 04:31 AM   #3
baro-nite's Avatar
Noting that SR is probably less effective at close focus, as per the manual.
03-15-2012, 07:47 AM   #4
RioRico's Avatar
As baro-nite said, SR is ineffective for handheld close work with the K20D. How close is too close? I'm not sure, and I'm too lazy to run tests now, but I'll guess that the limit is somewhere around 3-5x the focal length. So roughly, when magnification is around 1:4 or greater, don't expect much help from SR. At such short distances you'd best rely on flash or fast shutter or tripod. (Set SR off when using a tripod, of course.)
03-15-2012, 02:43 PM   #5
gordon_l34's Avatar
Hi All,
Thanks very much for your informative replies.
Regards.
camera, dslr, extension, extension tubes, length, photography, tube
K-x won't stop-down meter while using extension tubes? MikeS Pentax DSLR Discussion 37 05-28-2011 10:52 PM
Kenko Extension Tubes for K20D Goz Pentax SLR Lens Discussion 2 06-10-2010 02:32 PM
FUlly automatic extension tubes for K200D hallenti Ask B&H Photo! 3 05-27-2010 11:26 AM
Are extension tubes available for the K20D? jeryst Troubleshooting and Beginner Help 10 11-18-2009 03:30 PM
All times are GMT -7. The time now is 01:11 PM. | See also: NikonForums.com, part of our network of photo forums!
