03-19-2012, 07:52 PM   #1
mojoe_24's Avatar
Question about Flashes
Would I be able to take it off the camera and have it flash when I want or does it require the camera to be used?
03-19-2012, 07:56 PM   #2
Some flashes support wireless release and all can be used with a cable release. You can also set up a remote trigger. Which flash do you have in mind?
03-19-2012, 08:53 PM   #3
QuoteOriginally posted by mojoe_24 Quote
Most, if not all, flashes have a "test" button. You can fire the flash any time by manually pushing this button.
Not sure if I understand your question correctly though.
03-21-2012, 07:26 PM   #4
mojoe_24's Avatar
To clarify. I like messing around with long exposure at night. Would I be able to have the camera's shutter stay open and then use the flash (off the camera) to light something? And I'm not looking at any specifically right now. Most likely it'd be a cheaper one though.
03-21-2012, 08:19 PM   #5
Do a search for "painting with flash."
This is a good article: Painting with Flash.
Great photos: Harold Ross Fine Art
03-22-2012, 03:33 AM   #6
Lowell Goudge's Avatar
It works just fine, just set the flash manually for the exposure you want and push the test button.
But I will warn you now, be very careful (with respect to your images) as to where you physically stand, so that you do not block any of the light reaching the camera, otherwise you will get a lot of invisible people in your shots, not shadows or silhouettes but transparent human form outlines
03-22-2012, 04:52 AM   #7
mtansley's Avatar
Presumably, you'd need to trigger the camera, walk into frame, fire flash, walk out of frame and then stop camera.
Why wouldn't this give a silhouette, or would the background show through but only if you trigger the flash a second time.
I'm not questioning you (I guess I am really), it just sounds like rather an interesting thing to attempt, in addition to the OP wanting to paint with light.
03-22-2012, 06:08 AM   #8
QuoteOriginally posted by mtansley Quote
I am assuming that you are doing a very long exposure, so you use bulb, with the lens stopped down, and relitively low ISO.
I did this once with film, with about a 5 minute exposure, and walked about in the frame with a flash triggering it to light specific points.
The problem is, that there is some ambient light on the whole scene, and also stray light from the flash, that illuminates the scene, and you end up, if you are not careful, with transparent silhouettes, because the flashes are relitively high intensity but the ambient light, or stray light from a second flash, illuminates the scene behind the silhouette, but to a different level than the surrounding areas.
As i said, you generate transparent human forms in the image, unless you really plan out your exposure pattern.
I think in general the most critical thing is to always use side lighting, , i.e. you are never between the cone of light prijected by the flash and the lens, unless you want to creat the invisible man
03-22-2012, 06:15 AM   #9
mtansley's Avatar
Thanks for the details. Most interesting.
Actually, my intent WAS to try to create an invisible man, just the opposite to what you intended.
Makes photography all the more interesting, doesn't it.
03-22-2012, 06:53 AM   #10
If you want to create the invisible man, then I would suggest 2 flash pulses, one of the scene without you in it, set exposure for about 50% or -1-2 stops under exopsed, and then take a second flash with the flash hidden(to the camera) by your invisible man illuminating the scene again. it should work out nicely
03-22-2012, 09:40 AM   #11
mtansley's Avatar
Thank you.
I'll give that a try.
Nice to do something different and interesting WITHOUT using Photoshop or the computer generally.
03-22-2012, 01:37 PM   #12
Thank you.
what do they call it? Old School
do post the results, I'd love to see them.
03-22-2012, 02:00 PM   #13
mtansley's Avatar
Maybe Old School, it can also be called "I don't know Photoshop too well!!"
When I get something moderately successful I'll gladly post the results for you.
03-22-2012, 02:24 PM   #14
Maybe Old School, it can also be called "I don't know Photoshop too well!!" :
since I work with computers all day, I actually shoot jpeg because I simply hate spending any more time in front of a monitor than necessary.
This is a fun experiment
03-22-2012, 02:36 PM   #15
mojoe_24's Avatar
Thanks. Any recommendations on cheap, decent flashes?
camera, dslr, photography
studio strobes and hs flashes question piskota Flashes, Lighting, and Studio 9 09-01-2011 01:30 PM
Two flashes and one hotshoe...sync cable question... PentaxPZ Flashes, Lighting, and Studio 6 09-15-2009 02:03 PM
Quick question about flashes: AF 360 triggering Sigma 530 Andi Lo Flashes, Lighting, and Studio 3 07-28-2009 08:24 PM
Question for strobist: Ok to use different types of Flashes? SuperAkuma Flashes, Lighting, and Studio 19 07-12-2009 05:42 AM
What other camera co's flashes can use the same addons as my Pentax flashes? Grimlock Flashes, Lighting, and Studio 3 08-22-2008 05:39 PM
All times are GMT -7. The time now is 06:07 PM. | See also: NikonForums.com, part of our network of photo forums!
