01-09-2008, 10:52 AM   #1
Remote flash options
Hello, I'm currently shooting a Pentax Ist DL and have the AF-360FGZ flash. I would like to purchase one or two additional flashes for larger group photography and after reading the owners manual they only reference using the on camera flash with the AF-360 as the remote flash, or purchasing additional AF-360's. I don't want to spend a small fortune and I'm wondering if there are other, less expensive Pentax flashes that will sync with my existing flash or even other brands that would sync. Ideally I need a simple, easy solution.
Thanks so much, I hope I gave all necessary information!!
Karen
01-09-2008, 11:34 AM   #2
Sure......
.....$5 & up with a optical hot shoe slave flash sync that attaches to the bottom of any flash. You have to turn off your pre-flash (if possible) for the cheeper units however or they won't work. For $20 and up you can get a slave flash that counts the flashes and does what you want it to do, even if you use a pre-flash. The slave unit is built into the flash so no need for the hot shoe attachment. Go to ebay (or Adroma, B&H...) and do a search for "slave flash" and you will get examples of both the attachment and slave flashes.
HOWEVER, while these flashes are "auto" they do not do TTL or P-TTL. You will need to do a couple trial exposures to get the lighting correct (use your histogram) or use a flash meter.
I use a $5 slave mounted to the bottom of a garage-sale $1 flash and get excellent results with pepole, macro and product photography. The slave even has a tripod mount so I can situate the flash where I need it on a spare tripod or stand.
Good luck!
Perry
camera, dslr, flash, flashes, pentax, photography, sync
Off camera flash options? gsrokmix Flashes, Lighting, and Studio 4 01-29-2010 10:19 AM
Comparing current PTTL-compatible flash options mattdm Photography Articles 57 02-18-2009 06:45 PM
Macro flash options heatherslightbox Flashes, Lighting, and Studio 7 05-11-2008 02:56 PM
wanted: advice on flash options for K20? Douglas_of_Sweden Pentax DSLR Discussion 5 04-13-2008 03:36 PM
360 flash options jjfdvm72 Pentax DSLR Discussion 1 12-15-2007 10:40 PM
All times are GMT -7. The time now is 02:18 PM. | See also: NikonForums.com, part of our network of photo forums!
