03-25-2012, 05:34 PM   #1
krebsy75's Avatar
Our Poor K-x
We sold our white K-x to a friend's sibling on Friday night. Less than 24 hours later we see the following picture on FB:
Our poor K-x got pimped! What the hell kind of flash is that? Somehow I don't think it's P-TTL compatible.
Is that a k-mount adapter that I see? I didn't even know there were k-mount adapters (other than for attaching medium-format glass).
I'm baffled as to what lens that is. Any guesses?
I have a bad feeling this newbie went to a pawn shop or something and was talked into putting whatever on thier camera (our poor old K-x).
03-25-2012, 05:42 PM   #2
KansasPen's Avatar
The flash I have no clue. The "adapter" looks to be a teleconverter. My promaster 1.7x looks a lot like that. And again no idea on the lens.
03-25-2012, 05:52 PM   #3
krebsy75's Avatar
Ah... teleconverter. Now that makes sense.
03-25-2012, 06:02 PM   #4
the flash looks like a vivitar 550 from that blue ring. not sure though
03-25-2012, 06:03 PM   #5
Lens Buying Addict
monochrome's Avatar
Flash looks like a Vivitar 285HV (actually, no it isn't). I hope for his sake it has modern voltage or he could fry the electronics. FWIW, that flash is a classic workhorse. The basic design must be at least 30 years old. (I ahve one for my K series cameras).
03-25-2012, 06:07 PM   #6
The lens is some kind of Tamron. I'd guess a cheap 70-300 of some sort.
03-25-2012, 06:08 PM   #7
krebsy75's Avatar
The flash appears to have a secondary reflector and manual zoom head.
03-25-2012, 06:22 PM   #8
An old flash... I do hope it's compatible with the K-x, otherwise like the others said it may fry the K-x's insides.... The lens indeed looks like a Tamron 70-300, based from the focus ring.
03-25-2012, 06:27 PM - 1 Like   #9
boriscleto's Avatar
The teleconverter and flash are both Quantarays. The converter is an AF 2x and the flash is probably a QTB-7500A.
It's not a bad flash even if it isn't P-TTL compatible.
The lens is most likely a Quataray as well. They just rebadged Tamron and Sigma lenses over the years.
03-25-2012, 06:34 PM   #10
Philoslothical's Avatar
Here is the usual go to reference for trigger voltages. I'll admit that I have, and use, a similar looking Vivitar flash, which I picked up in a thrift shop for $0.50. It works fine, trigger voltage is fine, but of course it is manual only. There is a lot of variation in trigger voltages within the brand name, so it would be wise for him to check before continuing to use it.
03-26-2012, 01:47 PM   #11
Paleo Pete's Avatar
I agree on the Vivitar flash, my old Vivitar has the same blue ring and it works fine with the K-x. Yes I checked the voltage. I think mine is a 2800. Don't have it with me to check the model number, I have 3 I think...one is loaned out to a friend to use with his Nikon. My newer Vivitar does not have the blue ring but also works, voltage is somewhere around 5V I think. Ditto for the older one. None were above about 7 V if I remember correctly, including a Minolta unit.
camera, dslr, k-mount, k-x, photography
Poor, poor Florida jeffkrol General Talk 8 04-01-2011 01:32 PM
Poor poor Huckabee jogiba General Talk 16 03-05-2011 09:16 AM
Poor, poor Rand Paul jeffkrol General Talk 18 10-19-2010 01:57 PM
This poor chap . . . . Nubi General Talk 3 06-10-2010 02:26 AM
Poor performance from A-50/2 on K-x Asteroid Troubleshooting and Beginner Help 6 04-09-2010 11:27 AM
All times are GMT -7. The time now is 08:18 AM. | See also: NikonForums.com, part of our network of photo forums!
