I've converted a number of Pentaxes and their Samsung equivalents. I also started with a Sony F707, but the conversion on that involved actually removing the sliding hot mirror and replacing it with clear glass, then using a filter on the lens.
Regarding the difficulties of conversion, the older ones are the easiest. The *ist DL/DL2 and Samsung GX1L have relatively few wires to undo and the sensor assembly is in a fixed position. No shake reduction mechanism to worry about. The K10D/K20D are harder due to more wires, and the sensor is on adjustable mounts that need to be set correctly. The K-7 has even more wires and a very fiddly sensor assembly due to the ultrasonic shaker. I'm not sure I'd want to do a K-7 again
On the other hand, the older bodies need the AF adjusted in debug mode for each lens while the K-7 can use Live View and contrast AF. The K20D is somewhere in between, it still needs AF adjust but it has a rather rudimentary Live View so at least you can see what the scene looks like in IR. I used 830nm filters on all my conversions.
Nearly all the images on my website are with my converted Pentaxes plus a handful with the old Sony.
