Originally posted by kcobain1992 About a month ago I ordered three flangeless adapters (knockoffs of the original) for $7.50 each from ebay, hoping that I can remove the metal clip and use them to semi-permanently adapt some M42 lenses to K. They arrived today, and unfortunately they are VERY stiff. I mounted them on the lenses, but these do not rotate in the camera's mount more than, say, 5 degrees. As a simple glance, I didn't see any obvious difference between the original Pentax and these, so maybe you can help me solve my problem.
I've had the same problem from some of the knockoffs from China, for some strange reason they would not work with any Pentax m42 lenses but work very well and snug with the Soviet and East German lenses. The spacing between the lugs and the flange was slightly less than the original Pentax m42 adapter. If you have a digital caliper, measure the spacing between the flange and the lugs on both adapters. If you don't have a caliper, you can still do it but becomes a bit more tedious (many trial fittings).
Using an emery board. gently sand the lugs constantly checking the measurements or you can sand each of the lugs a fixed number of strokes, clean the adapter (soapy water bath, rinse and dry) mount the adapter to a lens then try mounting the lens on a K body camera. Repeat the process until you are satisfied with the fit. The adapters are made of brass and won't need too much sanding to get them to fit properly. I find the original m42 adapter too loose to be used as adapters for a semi-permanent conversion from m42 to K lens. The knockoffs are much better suited for semi permanent M42 to K conversion, if you make some modifications.
I have to get a few more myself, when these knockoff adapters are screwed on tight to the m42 lens, where is the red dot in relation to the lens' focus hash mark? Trying to find a seller that has adapters that place the mounting dot close to the focus hash mark is more important than the fit imo. Please provide the name of the seller if the red dot is near the lens focus hash mark.
