Originally posted by riff Yes a camera may use existing folders and filenames if it see understands them, but it is not specifically related to formating or lack of formating a card in a specific camera or computer.
Perhaps I wasn't clear enough -
with a formatted card there is nothing on which the camera has to take into account -
so it will create and use the next filename number in sequence (that the camera knows),
as it would do if no card swapping takes place.
But if a card from another camera with images/folders is used -
and if that other camera uses the same filename/folder convention
and the last filename number is greater than the last known/stored by the current camera-
there may be the possibility that the filename numbering sequence may follow those already on the card (from the other camera) -
whereas if the card was formatted - this would not happen -
thus in that way it is dependent on whether the card was formatted before use or not -
or have I misunderstood you?
