Originally posted by Canada_Rockies CIF will work fine if the camera and lens allow it. I don't think the aperture setting will matter unless you are using an M42 lens that you have to shoot stopped down.
I corrected my previous post. Yes, the ~f/8 cutoff applies to screwmount or T2-adapted or other manual-aperture lenses, anything without a working camera-to-lens aperture link. I have a zillion such lenses so I tend to think of those as standard, with the ~f/8 cutoff as a norm.
Quote: If you are using an A lens, then it helps to set the focus points to the centre focus point only. There are a few computer cycles involved in deciding which point to use.
I only have a couple A-type lenses and I haven't used them much so I didn't notice this. Thanks! Now I can use them intelligently in more diverse situations. I usually try to stay center-weighted anyway. Back in the day, that was the best there was, and I'm still comfortable there.
