03-30-2012, 03:11 PM   #1
bluebronco's Avatar
Switching ISO K20D
Is there a quicker way to change the ISO on the K20D without going into the function menu?
Thanks
03-30-2012, 03:58 PM - 2 Likes   #2
JohnBee's Avatar
Try holding the OK button and turning the front dial.
03-30-2012, 04:01 PM   #3
Unless the dial is occupied, on many settings, you can assign ISO to the front dial.
03-30-2012, 04:33 PM   #4
RickyFromVegas's Avatar
What I do is, go to Av mode, adjust ISO with the front dial, and return to M
Annnnnnnd...Never again!
Holding OK button and front dial adjusts ISO.
Thanks!
AHAHAH. Things I never bothered to find out....I really should read the manual.
04-02-2012, 01:40 PM   #5
bluebronco's Avatar
QuoteOriginally posted by RickyFromVegas Quote
Thanks!
Ding! Winner!
Never let my wife see this. She always says "Look in the owners manual."
04-03-2012, 04:36 AM   #6
baro-nite's Avatar
Like Ricky, I just did a facepalm after learning how to use the OK button to change ISO when in M mode. But the manual -- in the K10D manual at least, it says nothing about the OK button in the section on changing the ISO sensitivity, nor on any page containing the acronym "ISO" (I just checked in the PDF version). I never would have discovered this on my own, so thanks JohnBee!
04-03-2012, 05:01 AM   #7
Pretty sure that was a firmware update change, so wouldn't have been in the manual!
04-03-2012, 05:13 AM   #8
baro-nite's Avatar
QuoteOriginally posted by pxpaulx Quote
Ah, you're right -- version 1.10. I suppose I should print off all the firmware changes and paste them into my manual. And annotate the index...
camera, dslr, iso, k20d, photography
K20D and ISO Setting Barron Troubleshooting and Beginner Help 2 09-23-2011 05:24 PM
K20D switching from raw to jpg on its own??? ismaelg Pentax DSLR Discussion 5 04-11-2011 05:25 AM
m4/3 high ISO better than K20d ?? arbib Photographic Technique 12 09-10-2010 06:30 PM
K-x versus K20D ISO test rparmar Pentax DSLR Discussion 68 08-26-2010 02:19 PM
K7 - k20d iso Ed n Georgia Pentax DSLR Discussion 4 06-22-2010 09:43 AM
All times are GMT -7. The time now is 06:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
