04-05-2012, 06:32 PM   #1
Using wired remotes
Bought some wired remotes. I don't see any place to plug them in. Have all 6-12 mp Pentax dslr's. Can I use them or did I buy the wrong things?
Thanks
04-05-2012, 06:54 PM   #2
Docrwm's Avatar
Which models do you have? The K-x & K-r only use IR.
04-05-2012, 07:20 PM   #3
ist, k2000, kx
04-06-2012, 06:39 AM   #4
Docrwm's Avatar
The K-x and K-m/2000 do not use wired remotes, only IR remotes. Don't know about the ist but my guess is that its in the same line (entry level) and therefore does not either.
04-06-2012, 05:03 PM   #5
The k200d needs adapters on the hot shoe and base of the flash, it gets very cumbersome and expensive! You might want to go with wireless triggers.
Tuggie76
04-06-2012, 05:16 PM   #6
Ex Finn.'s Avatar
QuoteOriginally posted by tuggie76 Quote
Tuggie76
He is referring to wired shutter releases I believe.
04-06-2012, 07:02 PM   #7
O/k, the plug for the shutter release is under the little door on the left side of the camera, I have a wired and wireless type and both work well.
Tuggie76
camera, dslr, photography, remotes
wireless remotes for the Q. barondla Pentax Q 23 03-22-2013 05:24 AM
Testing IR remotes with your camera's LV dosdan Accessory and Memory Articles 3 01-27-2012 01:26 PM
Landscape Wired Sailor Post Your Photos! 10 01-22-2011 05:47 AM
Question about IR remotes Metalwizards Troubleshooting and Beginner Help 5 01-08-2011 04:06 PM
All times are GMT -7. The time now is 12:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
