Quote: Such images are developed according to your camera or RAW developer settings, and/or factory defaults if you use them. Going from RAW to JPG or TIF or whatever involves PP: development. Development means using some subset of the RAW data captured by the sensor. Every RAW image requires PP, or it's nothing. That's just how this stuff works, eh?
Me thinks thee might be getting a wee bit semantical there Mr. Roco
Quote: Is it possible to have a perfect RAW photo? Or does it have to be fiddled with (white balance ect) when its converted to JPEG?
And also do we rely too heavily on post processing and consider it normal?
I don't think he was asking "can you take the 1s and 0's output by your camera's sensor to produce an image without any interpretation?" After all you could dump them and display them as a series of one and zeros, as a numerical pattern, and not a picture at all. There would be no purpose in asking such a question. He is asking, if you can take a RAW image from your camera and have any hope that it will be printable. The fact that it is a "RAW photo" implies that the in camera RAW processing has already been done. The RAW data without interpretation is not a photo.
The answer to the second part of the question would be..
Without post processing, what you have is a picture interpreted by a set of technical specs that best represent the setting you'd use for an "average" photograph as interpreted by the camera manufacturer. It may create an "average version" of what you saw, but not really what you saw. If what stood out for you was the red in a sunset, you have to do what it takes to bring out that red, so that the viewer understands why you took the picture. If some of the elements had an emotional impact, you need to emphasize them in PP so they have the same emotional impact in the print they did in real life. You have to be moved by something in the scene to take the picture, then you have to create the same (or some other effect)* in the photograph so it moves the viewer. The average settings provided by the camera manufacturer are very unlikely to do that.
* You can just as easily look at a scene that means something on it's own, but then subvert that meaning into something not present in the original, through optical illusion. That in itself is part fo the art of photography.
