12-28-2006, 08:07 AM   #1
Some K10D Jpeg samples ...
Here's some more at:
K10D and manual focus lens - FM Forums
12-28-2006, 08:16 AM   #2
They're all very good (I'm not even biased because I'm from Pennsylvania) and you've been linked at dpreview, too.
Are you KIDDING ME!?....Phil, look at these K10D shots!: Pentax SLR Talk Forum: Digital Photography Review
I had a VS1 28-90 that was quite good, but alas I sold it because it was too heavy and I had too many other lenses covering the focal length. But the shots were amazing! (Mine was a third series, might have been made by Kiron.)
--Sean
12-28-2006, 08:19 AM   #3
Great shot Lisa and I like some of the ones I saw over on the FM forum even better. And they say Pentax can't shoot sports!
NaCl(of course "they" say a lot of stuff which is complete hogwash)H2O
12-28-2006, 08:45 AM   #4
thanks for he comments
I was wondering if any of you know anything about teleconverters?
I was interested in either a 1.4, 1.7 or even 2.0
Can any of you tell me a little about the pros and cons of using one and which one's you prefer? I see some older ones by Pentax, some newer ones by Pentax and Sigma, Tokina, ect
any differences?
What can I expect?
thanks alot
12-28-2006, 09:24 AM   #5
Hi Lisa,
You may want to post a question in the lens forum. I'm sure you'll get a wealth of answers.
(I have the 1.7x teleconverter that actually makes manual focus lenses autofocus. It is OK, but I haven't tried it on the K10 yet.)
--Sean
12-28-2006, 09:27 AM   #6
vievetrick's Avatar
Hi Lisa and glad you joined here. I saw you shots this morning and wow. Great work and read it took you some practice with that manual lens. Anyway, glad to see you here and hope to see more of your work with the K0. I am sure you will get direction about the TC and as Carpants suggested maybe post a question in the lens forum.
Welcome again
12-28-2006, 09:51 AM   #7
ok thanks...I will ask over there. However one quick question ....How does a 1.7 teleconverter actual make a manual focus lens into an autofocus lens?......thanks
btw, are you happy with your 1.7 images?
12-28-2006, 03:15 PM   #8
"I have the 1.7x teleconverter that actually makes manual focus lenses autofocus"
sounds good.. but i will be happy with the kenko 1.5 i have coming if it dosnt mess up the image quality too much and my auto focuse lenses still auto focus.. .. miracles i dont expect.. he he
trog
12-28-2006, 05:59 PM   #9
Alvin's Avatar
Lisa, those shots were jaw dropping! Nice find on that lens and best of luck with your search for a TC.
Just so that I can get a feel for the range of the 210 mm, how far would you say you were from Crosby when you took that SS?
12-28-2006, 08:56 PM   #10
Alvin, The Crosby shot was a cropped image...to give you a better idea of how much I cropped and how far back I was, here is the full image
I would say the 210mm lens gives you 80% very good coverage of the ice.....I think 300mm would be perfect but only if it was a 100mm-300mm zoom lens because there are times when you want to capture the action from further away too. I was about 14 rows up from the front glass for the game
12-28-2006, 09:42 PM   #11
Alvin's Avatar
Lisa, thanks for the heads up. That's a good amount for me. Almost the same as my p&s but mine are blurry all the time due to low iso and shutter lag.
Now correct me if I'm wrong... 1.7 TC that Carpents has + 70-210 mm Vivitar = 119-357mm (and I lose how many stops when I use TC?). Oh shoot, forgot the 1.5x factor to get 35mm equivalent (178-535mm?!?!) WOW! That is more than two times my old Fuji (38-228mm equivalent). Sorry guys. I'm suffering a touch of lens lust. Now if I can just convince the wife to go this route instead of the fisheye. (see here to explain)
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/1839-my-lba-completed.html
12-29-2006, 06:44 AM   #12
vievetrick's Avatar
Lisa Curious about your PP work. The ise looks like ice. I have scene other shots that the person has had issues getting the color right but yours look very nice. Would you say this is becuase the camera got it right or did you have to do much PP work to get the WB or color correct?
12-29-2006, 07:24 AM   #13
Thats a good question,
my post process work didnt really require much.....some of the images needed a slight exposure increase of .25 stop
Then I ran an Auto Contrast correct
usually after that the image looks fine.......I may run 1 or 2 passes of unsharp mask at about 80% .03 0
All done in Photoshop CS or CS3 ( Beta )
Perhaps the camera does a very good job of capturing the Highlights before blowing them out?.....altho some may say that the K10D is actually limited in DR compared to other DSLRs....I dont know
12-29-2006, 09:30 AM   #14
the camera has done a very good job.. they are slightly under exposed which has helped it.. u cant bring back blown high lights..
the overall whiteness has caused the camera to expose lower.. with white against a darker background some minus e/v would be needed to avoid the whites blowing..
the images look slightly blue-ish to me.. not a criticism just a comment
trog
camera, dslr, k10d, photography
K10d settings for out of the box jpeg herzzreh Pentax DSLR Discussion 7 11-05-2010 12:51 PM
Some K-r high ISO JPEG samples Asahiflex Pentax News and Rumors 34 10-11-2010 04:29 PM
New K10D and JPEG clevo Pentax DSLR Discussion 21 01-22-2008 06:09 AM
K10d JPEG quality rwa Pentax DSLR Discussion 35 11-29-2007 09:34 AM
K10D softness in JPEG Salminus Pentax DSLR Discussion 40 09-15-2007 01:36 AM
All times are GMT -7. The time now is 02:41 AM. | See also: NikonForums.com, part of our network of photo forums!
