01-14-2008, 09:39 PM   #16
PentaxPoke's Avatar
QuoteOriginally posted by benplaut Quote
Pretty much, the green button is "instant green mode" in most cases.
Good point.
I love the green button! Since I have "discovered" it, I haven't taken my k10d off of the M. It quickly gets me to what the k10d thinks is a good exposure (based on the program line setting) and then I can easily take over from there. If I want more speed, I might click up a couple stops on the shutter, and down a couple on the f-stop keeping the "needle" in the center. I can tweak the iso if I want as well. It is really nice for those of us who have yet to develop a "calibrated eyeball" for exposure. I have yet to take a picture using "green mode" and if I am strong, I never will.
The more experienced photographers here might say I am cheating, and using the "instant green" but it helps me to get to "zero" faster than I could otherwise. I am still thinking about exposure and settings though, and changing them based on the situation. It seems to me a good way to get weaned off of the P&S mindset.
Did I mention, I just love this camera I should be working right now, but I can't keep my hands off of it.
01-15-2008, 01:57 AM   #17
pentagor's Avatar
Khm... sorry for this... you are talking about K10D? K100D does not have a "green button", right?
Edited:
Looking at the manual, I found this:
So, K100D also has a "green button", except it is not green at all... :-) It's blue?
01-18-2008, 07:28 AM   #18
QuoteOriginally posted by herzzreh Quote
What's the point?
Canon doesn't have one.
01-18-2008, 07:37 AM   #19
I know what it does, but what's the point? Someone educate me, please.
Its just a reset function button, no more, no less.
01-18-2008, 07:41 AM   #20
Lowell Goudge's Avatar
QuoteOriginally posted by RiceHigh Quote
Yes, it is a "reset" of the exposure to what ever you have set for preference, Program line, Shutter priority or apature priority.
I have asked pentax to add a 4th function, specifically to just meter.
01-18-2008, 07:56 AM   #21
and
QuoteOriginally posted by PentaxPoke Quote
Good point.
amen, me too.
Its also a nice function to use (I have it set to av shift) to do some metering and note the results, because u can press it once to meter and then the result will stick, so I can set the meter to spot and take a few samples around the scene and observe them.
I use M and X modes 97% of the time these days. I used to do Av around 95% of the time but now I hardly use it.
01-24-2008, 04:38 PM   #22
Manual metering HOORAY!
THANKS SO MUCH
I always thought I needed to use SMC-A lenses of some variety! But since y'all explained how to use the AE-L button (on my k100d) I can use old lenses!
It certainly isn't that clear from the documentation. I just tested it on an old Ricoh 50mm f2 I had, with no auto setting -
AE-L button set to adjust shutter speed while in manual mode
Select aperture on lens
Hit button - stops down - metering happens - shutter speed adjusted accordingly
I am psyched! Thanks for the input.
01-24-2008, 07:09 PM   #23
jgredline's Avatar
That little green button is great!!!
camera, dslr, photography
Green button fekish Troubleshooting and Beginner Help 4 10-06-2010 03:33 PM
SR and green button slow2focus Troubleshooting and Beginner Help 7 12-12-2009 11:56 AM
Green Button walro Troubleshooting and Beginner Help 1 05-19-2009 03:25 PM
Green Button res3567 Pentax DSLR Discussion 16 04-07-2009 11:41 PM
green button Fl_Gulfer Pentax DSLR Discussion 38 09-04-2008 10:45 PM
All times are GMT -7. The time now is 08:00 PM. | See also: NikonForums.com, part of our network of photo forums!
