Show Printable Version 8 Likes Search this Thread
04-24-2012, 04:47 PM   #16
Banned
QuoteOriginally posted by TigerLord Quote
Short of extra battery use and the lack of DoF preview, why don't most semi-pro/pro photographers use LV?
I only used the LV feature of SLRs when mounting the camera on a tripod for focusing on the moon. I was zooming in to maximum magnification to make sure I don't focus past the moon. It was useful for that.
For regular use, I just found LV to be poorly implemented in DSLRs - slow refresh rate and a flicker at high magnification did not combine well with handholding.
That being said, I've been using the LCD screen of my Olympus E-PL2 for the past 5 months and now I feel weird about using a viewfinder at all.
QuoteOriginally posted by Cannikin Quote
By far the most important thing for me is stability: 2 points of support (hands) vs. 3 points (hands + face) plus added stability from keeping your elbows tucked in rather than suspended out in the air.
Nobody is forcing your elbows away from your body when using the LCD screen. The camera doesn't need to cover your face anymore, so there is no need to hold it at that height.
04-25-2012, 02:00 AM   #17
Not sure how fast the LV is on a K-5, but when shooting through LV on a K-x, (even by shifting AF to PDAF where the mirror has to flip down and flip up again) it's just really, really slow. Misses a lot of moments. I only use LV when light is too low for my eyes, and when using manual lenses with thin DoFs (e.g. M 50 1.4)
04-25-2012, 03:52 AM   #18
Lowell Goudge's Avatar
For me, and this is from someone who has used both a DSLR and a compact Bridge camera (with electronic view finder) for years, there are multiple points to consider
As many have mentioned, for low light, nothing beats an optical viewfinder, the same is true whe using long lenses, the correct technique for shooting makes use of the fact that your camera is against your eye, and although it seems as if there is no real support there, it stabalized the camera to a great extent. Holding the camera away from your body with long and/or heavy lenses leads to shake and blurred images. Also using live view induces shutter lag
Live view has uses when on a tripod, or when you can't hold the camera at eye level and get a shot, here however, the real benefit would be if the rear viewing screen could be rotated (on Pentax it cant)
04-25-2012, 06:17 AM   #19
RioRico's Avatar
That depends on how low is the light. I find that LV on all my digicams normalizes light levels, dimming the bright and amplifying the dim.
No argument there. LV on my K20D is NOT good for active subjects.
Sometimes tripod+LV usage in a bright environment also requires a wide-brim hat or that traditional black cloth. LV is of course mandatory with IR-modified cameras. And yes, a rotating screen is a great help.
04-25-2012, 07:55 AM   #20
Although the light level is "normalized" and I cant argue that point, my experience with Electronic Viewfinders in low light is that the image noise is so high, that the image is almost impossible to identify out of the noise.
I will however conceed that as sensors improve this is becoming less of an issue, and in extreme cases the amplification might actually help in seeing something out of nothing, but I am not yet convinced that an electronic viewfinder is yet at the quality of an optical one for low light.
Also, when manually focusing the sharper although dim image in the viewfinder is easier to deal with than a noisy one on the LCD and AF still struggles in low light with live view
04-25-2012, 08:14 AM   #21
monochrome's Avatar
QuoteOriginally posted by Ole Quote
You cannot really see what's on the screen in strong light so your compositions become, well, not compositions. And it helps reduce camera shake to not to have to hold the camera out in front of you like a cheap phone with a built in so-called camera...
In my experience neither is really true at focal lengths 135mm and below. Above 135mm I need the 3rd point of contact, i.e. my brow ridge, to stablize the camera. The PDAF vs. CDAF issue is real, so there is merit to needing a viewfinder for moving subjects.
  1. At max brightness the K-01 LCD is easil;y viewable in any light Ia hve encountered
  2. Held properly (classic SLR grip) the K-01 can be made as stable as a viewfinder camera
Consequently, neither alternative is universally the better alternative. Each has its strengths and weaknesses. In my case foucs peaking on live view is a significant aid to my deteriorating vision. Shooting that requires a viewfinder certainly isn't fun and is only marginally possible.
04-25-2012, 10:27 AM   #22
Banned
Note that LiveView in this thread is strictly about using the LCD screen, not about the use of an EVF:
"Why do you keep using the [viewfinder] instead of the screen on the back?" (his exact words were the "hole for the eye thingy..." )
04-25-2012, 10:51 AM   #23
timh's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
I was about to say the same thing. An EVF solves most of the problems associated with a rear LCD, which is why all the serious* MILCs** have one.
(*OK, controversial)
(**Someone should register MILChunter.com - wanted ads for mirrorless cameras. Or not.)
04-25-2012, 05:52 PM   #24
Pål Jensen's Avatar
Live view is awful for composing and aiming and focusing. It is useful for judging exposure and contrast range.
04-25-2012, 08:04 PM   #25
bigted's Avatar
Location: Jessica Lake, Whiteshell Provincial Park, or Winnipeg Manitoba, Canada
This is an interesting thread. As a relative newbie (bought my K-r last September), my simple answer is that I take better pictures through the viewfinder over the LCD screen. I didn't know the technical reasons why, it's just what I had noticed. It's been really interesting to read that there are real reasons why the viewfinder can trump the LCD.
bigted
04-25-2012, 10:06 PM   #26
Banned
QuoteOriginally posted by Pål Jensen Quote
Wanna bet? Try to compose, aim, and focus a shot like this with an optical viewfinder:
Just make sure there are no people around, or they'll think you're having a heart attack or something.
04-25-2012, 10:58 PM   #27
madbrain's Avatar
I never missed Live view on my K200D, which doesn't do video.
I use the viewfinder for stills even though my K-r and T3i both have live view.
However, for shooting video, the LCD screen, ie. Live view is the way to go - and the only option actually.
04-25-2012, 11:52 PM   #28
timh's Avatar
Accepted, however I tried exactly this kind of shot yesterday with LV and it still took 6 tries to get the framing I wanted because the bloody LCD isn't articulated! Impossible to see at that angle without getting my knees down in the wet grass.
04-26-2012, 01:02 AM   #29
Anvh's Avatar
I often use the LV in lowlight, that's the only way i can manual focus the Sigma 30 f/1.4, the viewfinder is then too dark to really see what you're doing.
04-26-2012, 06:43 AM   #30
Pål Jensen's Avatar
Still is awful and would never do that. This image need a tripod (probably). Theres too little DOF; the whole subject is not in focus and the background is annoying...
answer, camera, dslr, k5, lv, photography, viewfinder
different lens behavior in viewfinder and live view AF xxlover Pentax K-r 5 03-18-2012 08:32 AM
Any side effect for using live view for "too long"? (viewfinder hood) telly0050 Pentax K-5 & K-5 II 12 01-23-2012 05:28 AM
Focus correct with Live view, but not through the viewfinder? JGB Troubleshooting and Beginner Help 28 11-19-2011 09:52 AM
K-r & manual focus lenses - Live view vs viewfinder figmental1978 Pentax K-r 32 04-10-2011 11:18 AM
K7 live view sdh87 Pentax DSLR Discussion 3 06-07-2010 10:22 PM
All times are GMT -7. The time now is 10:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
