12-28-2006, 09:39 AM   #1
arbutusq's Avatar
USB connection problem..K100D
I plugged my K100 into the USB port to download some images this morning and got a message stating that there was a power surge on the USB hub and that a device (Presumably the camera) has exceeded the power limit of the hub port.
THe USB ports work fine with other devices. Any Ideas what is going on?
12-28-2006, 11:01 AM   #2
usb ports only supply so much power.. some hubs are self powered some arnt.. a four port hub if not self powered can exceed the main usb ports capabilites..
the camera being self powered should not require much if any power from the hub thow..
if u have other devices plugged into the same hub try removing some.
i use a card reader to be honest i finding it easier than plugging the camera in..
trog
12-28-2006, 11:11 AM   #3
arbutusq's Avatar
THanks for the reply. I do have a card reader so it isn't life threatening.
The camera has worked through my usb ports before, it just doesn't work now. I've tried other batteries and all my ports...nothing.
12-28-2006, 12:27 PM   #4
Has anything changed since the camera last worked on the hub? Are the camera batteries particularily low? Are you plugging it into the same port on your hub? I know that any of these should have no bearing but USB can sometimes do funny things. I own a DS and have always used a reader so I don't know, but does the camera need to be on? Also could it be the cable? I know the cable for the DS is proprietary, but if the K100 isn't, could you try a different cable?
NaCl(just a few different thoughts)H2O
12-28-2006, 02:31 PM   #5
arbutusq's Avatar
QuoteOriginally posted by NaClH2O Quote
I've tried everything you've suggested, nothing helps. I can download via usb on other computers so it must be hardware related.
12-28-2006, 06:26 PM   #6
Alvin's Avatar
QuoteOriginally posted by arbutusq Quote
Only other things I can think of. Try a different SD card, or a different set of fresh batteries? Reinstall the Pentax driver on your PC?
12-28-2006, 09:19 PM   #7
rfortson's Avatar
The camera connects to the computer?? Who knew?
Sorry for the meaningless post. I couldn't help myself. I hope you figure out the problem, which most likely lies within the vagaries of Windows XP and your USB controller. At least, that's been my experience. I have one USB port that just won't act right and I finally gave up trying to whip it into shape.
camera, dslr, hub, photography, port, power, usb, usb connection
Snapped off USB port on k100d BrianR Pentax DSLR Discussion 7 12-14-2010 09:33 AM
Problem with remote connection on K200D PALADIN85020 Pentax DSLR Discussion 2 09-18-2010 01:12 PM
USB connection sub5runner Troubleshooting and Beginner Help 6 06-15-2010 07:13 PM
Disconnected camera w/out ejecting and now NO USB connection imno007 Troubleshooting and Beginner Help 11 05-29-2010 09:26 AM
Download: Remove SD card or plug in USB connection? laissezfaire Pentax DSLR Discussion 40 12-16-2008 10:41 AM
All times are GMT -7. The time now is 10:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
