04-24-2012, 05:46 PM   #1
does a K7 support 64GB SDHC cards?
I've been using a good SanDisk 32 GB SDHC card since I got my K7 (30MB/s, class 10). It works great.
I'm now adding a second card and I wonder if I will be okay if I get the 64 GB version of the same card. Does the K7 support cards this large?
04-24-2012, 05:49 PM - 1 Like   #2
64Gb cards are SDXC, not SDHC, but indeed, they are supported. You just have to upgrade your firmware to the latest version.
04-24-2012, 06:00 PM   #3
Thanks, Adam.
04-24-2012, 06:01 PM   #4
Banned
You'll also be wanting to check what's under the hood of ones computer as well.
If you have a platter hard disk drive (as opposed to hybrid or SSD) then ones computer will have a really good time when the computer tries to defrag.
Under a typical Windows 7 example with an above average sized platter hard drive; if one downloaded the entire 64Gb card; then it might take quite the number of hours to defrag.
04-24-2012, 06:50 PM   #5
QuoteOriginally posted by Medium FormatPro Quote
I'm using a Mac Pro with a traditional 2 TB hard drive to store my photos on. My admittedly vague understanding of things is that OSX doesn't need to defrag hard drives, or does it in the background or something -- my roundabout way of saying, I have never defragged a hard drive on a Mac, though I used to do it regularly on my PC.
04-24-2012, 07:03 PM   #6
Banned
That MacPro is a far above average choice, but...
You may very well want to recheck into that defrag thing - especially on a drive that large - even well before electing to purchase the 64gb memory card.
Whether is Mac or Windows; for most people I would not suggest a memory card that large without either a very good hybrid drive or an ssd. It may very well lead to major issues with the computer - ie not quit enough time to properly defrag and having to interrupt a defrag - which is alright at times, but not on a frequent basis.
On the other hand; I would try perhaps two or three 32gb cards
04-24-2012, 07:17 PM   #7
I am perhaps a little dense -- I don't really understand why it would be better to import photos from 2 32 GB cards back to back, instead of 1 64 GB card in one session, in terms of hard drive fragmentation. If you could explain that a little better it would be helpful.
edit: assuming all cards are full, i.e. 64 GB of photos incoming from either two 32 GB cards or one 64 GB card...
thanks
04-24-2012, 07:26 PM   #8
If you're on a 64-bit OS, you shouldn't have any memory issues associated with cards > 32gb, I don't think. If you have more than 4Gb of RAM, then you've likely got 64 bit.
04-24-2012, 07:34 PM   #9
I have 6 GB of RAM, but I'm on OSX 10.5.8, which is several versions behind the times, so it might not be 64-bit. (There are technical reasons for not having upgraded OSX due to my music and video production software, it's not entirely laziness that has kept me at 10.5).
04-24-2012, 07:41 PM   #10
I appear to have a 32-bit kernel, from my quick check in terminal of the kernel, as far as I understand it.
04-24-2012, 09:12 PM   #11
QuoteOriginally posted by patrickw Quote
Then you're wasting 2GB of memory. It is mathematically impossible to address more than 4GB of memory in a computer with a 32 bit word. Doesn't matter if its Intel, Motorola, Windows or MacOS or Linux.
2 ** 32 = 4,294,967,296 = 4G
As far as fragmenting a hard drive, the NTFS file system used by Windows is much less susceptible to fragmentation than the FAT32 file system used in Windows 95 and Windows 98.
camera, card, dslr, gb, k7, photography, sdhc, support
Faster SDHC cards? dgpaterson2000 Pentax Medium Format 3 07-22-2011 08:19 AM
Can K-5 handle 64GB SD Cards ? Ragnar Pentax K-5 13 06-05-2011 01:36 PM
class 10 SDHC cards Glen_S Pentax Camera and Field Accessories 20 04-11-2011 11:48 PM
SDHC cards jonhock Pentax Camera and Field Accessories 11 08-15-2010 10:37 PM
All times are GMT -7. The time now is 08:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
