Originally posted by kc4braves Well, the image played back on the camera memory. Also the card read, "Folder empty" on the computer which it wouldn't do if anything, good or bad, was there. But...to be sure, I also tried indoor pics on auto.....nothing. I think the card was just messed up for whatever reason.
Oh I can take some messed up pics. usually over exposure is more likely for me but...the pics still show up even if the picture is totally blakc or totally white.
Thanks,
KAthy
Again, what software on the PC is telling you "Folder Empty"? Are the images jpegs, or RAW files? If they're RAW, are they DNG or PEF?
The software you are using is important because some photo-specific software may not recognize PEF or DNG files. Windows Explorer would at least see them, but might not know what to do with them.
When you display them on the camera, it should show the file type.
If all else fails, try using the USB cable to copy the images to the PC. Normally, most of us here recommend using a card reader in your PC, but if the camera can read the card, but the PC can't, you may be able to recover them using the USB cable. If that works, copy the images to the PC and then reformat the card in the camera, not the PC.
