05-13-2012, 05:36 AM   #1
Stop-down problem with K-x
Hello all..
I'm Italian and I know I can't speak english very well. I've just registered beacuse I have a great (strange?) problem about the stop-down metering ONLY at f3.5 and lowers with the 50mm pentax-m f1.7 and 28mmm pentax-m f3.5: when framing a very light scene (even a blue sky at noon!), I press the green button to perform the stop-down metering and the camera always suggests me 0.3" as shutter speed. The only way to use these lens at these apertures is to adjust the shutter speed manually, without rely on the exposure meter. Few days ago I updated the firmware (1.03), but I can't remember if I had this problem before.
I use only these lens (for study and work)... All suggestions are welcome!
05-13-2012, 05:56 AM   #2
Mareket's Avatar
I've had this problem and I THINK it means that the fastest shutter speed still isn't fast enough for a correct exposure, so you'll need to drop your aperture or ISO and then meter again.
Then again you say you can use them by adjusting the speed manually, so I dunno. This is the general idea I've gotten from the problem over the time I've had my K-x though.
05-13-2012, 06:12 AM   #3
QuoteOriginally posted by Mareket Quote
I tried to adjust ISO and aperture but it still gave me the same shutter speed. Adjusting it manually lets me to use the lens completely manually. I also noticed that the problem not always occurs: rarely the stop-down metering works as expected. It seems to be a kind of a bug. Is it possible?
05-13-2012, 06:27 AM   #4
kcobain1992's Avatar
Yes, it is a bug of the K-x, as far as I can tell. What it does actually tell you is that the combination of aperture and ISO selected is anyway too bright and you probably don't want that. If shooting at ISO 100 and wide open still gives you headaches, try a 2-stop ND filter (a polarizer also works).
05-13-2012, 06:59 AM   #5
Yes, it still gives me 0.3". Maybe the correct behaviour would be to suggest the fastest shutter speed, not 0.3"! It seems I'll have to come to terms with that..
Thank you for your answers.
05-13-2012, 08:46 AM   #6
jatrax's Avatar
QuoteOriginally posted by Aeldrhamir Quote
The correct behavior would be to flash an error rather than suggest a speed that will not work. This problem has stumped a number of k-x users over the years. I do not remember ever hearing about it on the k-r, so maybe they changed it.
05-13-2012, 08:48 AM   #7
jatrax's Avatar
And there is nothing wrong with your English, better than many school graduates here these days.
camera, dslr, f3.5, lens, pentax-m, photography, shutter, stop-down
manual stop down problem ckswong Pentax K-5 4 04-06-2012 07:36 PM
Problem adjusting f-stop on 50mm prime Unregistered Visitors' Center 9 11-21-2011 10:27 PM
10 Stop ND Problem Graham V Photographic Technique 10 05-17-2010 09:02 AM
f stop problem LosHollyBeach Troubleshooting and Beginner Help 3 03-06-2010 09:04 PM
k100d stop-down metering problem stanjo Pentax DSLR Discussion 4 11-05-2007 12:37 PM
All times are GMT -7. The time now is 01:40 AM. | See also: NikonForums.com, part of our network of photo forums!
