I have a k10d fitted with a katz eye split prism focus screen.
Through the viewfinder with the auto focus on, fitted to a tripod with using time delay actuation, and auto focus single the image in the split screen is always slightly out of line but the focus hexagon is lit up.
If I now set the focus on manual and line the lines on the split screen up perfectly again the focus confirmation hex comes on.
If I take two images with an object with a vertical line with a sharp edge so I can clearly see what the screen is showing to aid focusing then the manual image is much sharper when zoomed on the screen on my computer to view that edge.
If there is an an object or foliage behind the vertical line object it will be more in focus with the auto focus than with the manual .
I assume therefore that the k10 is back focusing but why is the focus confirmation coming on for both manual and auto when there is a difference in the focus ring setting?
Is possible the katz eye is effecting the focus? I thought the focus screen had no effect on the auto focus?
Finally I should mention this difference in the viewed focus via the split prism and the aforementioned focus results are the same with any lens I try.
