05-20-2012, 07:24 AM   #1
i_trax's Avatar
Linking AE to AF Point during Multi-Segment Metering
Hi, could someone explain what exactly does this do please?
did anyone experiment with it using K5 and K7?
when it is useful, in what light conditions?
kind regards
jack
05-20-2012, 07:45 AM   #2
Marc Sabatella's Avatar
Multisegment metering divides the frame up into a bunch of regions, meters each, then goes through some sort of fancy algorithm to decide what overall exposure to use. If you link AE to AF point, then that algorithm takes into account where you focused, otherwise it doesn't. So in the case of a subject with a bright background, regular multisegment might render the subject darker to avoid making the background too bright. If you link AE to AF point, it will try to expose your subject with less concern for the background. not complete disregard - it doesn't change it into spot metering. But it gives more weight to your subject.
As for when to use it, I wouldn't think of it as being for specific light conditions - it's more a personal preference thing. Although I suppose for some, their preferences might change with different subjects.
05-20-2012, 08:18 AM   #3
Canada_Rockies's Avatar
To amplify Marc's reply, linking AE to AF has no effect on my photographs because I never use multi-point autofocus. Anyone else using centre point only for AF will not see any difference at all.
05-21-2012, 05:28 AM   #4
i_trax's Avatar
thank you All,
I could not see much diference , hence my question, need to do more experiments.
kind regards
jack
ae to af, camera, dslr, photography
I got multi-segment metering on an M42 lens--how?! MobiusOne Pentax DSLR Discussion 15 11-29-2011 08:45 AM
Super-Takumar 135/2.5 M42: Multi-Segment Metering on K-x? RolloR Pentax DSLR Discussion 2 11-07-2010 04:48 AM
Linking AF point and AE during multi-seg metering geckogrin Pentax DSLR Discussion 3 08-21-2010 07:59 PM
Sigma 30mm f/1.4 compatible with Pentax K-7 Multi-Segment Metering brosen Pentax DSLR Discussion 4 10-25-2009 10:29 PM
multi-segment metering and M lenses newarts Pentax DSLR Discussion 11 03-09-2009 01:45 PM
All times are GMT -7. The time now is 05:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
