Originally posted by Anvh Run the numbers on it and you will see that hyperfocal distance is closer by with wider lenses then with longer lenses.
If I understand your response (and I think I do), I would have to say 'half-true', but that statement is based on my typical shooting style and may not apply to anyone else.
When I reach for a longer lens, I also tend to be aiming at subjects that are somewhat closer to infinity focus. At that range, the depth of focus tends to be deep enough to cover any errors in critical focus. If on the other hand, I was shooting at the closer end of the focusing range using a longer lens, you are absolutely correct. The depth of focus can be razor thin. Those are also the circumstances in my photography where I have time to put my brain to use and hand tweak both focus and exposure.
