05-27-2012, 03:43 PM   #1
A little lube helps turn me on
Heya! I'm having a great time with my Pentax K-x but as time goes on i've noticed that the power switch is getting harder to flip. I haven't had any problems with obvious dirt getting into it (white body so it would be obvious if i had), and it's not like i've been handling the camera with muddy hands, but the switch is not as easy to flip as it used to be. It's a minor thing but i was wondering if there's any decent kind of lube for a plastic part like that? Would a touch of silicon lube be good for plastic? Can you suggest any other juvenile jokes i missed in the title?
Thanks!
05-27-2012, 03:52 PM   #2
Any kind of lube sounds like a terrifically bad idea. Try compressed air to get at hidden grit. Contact cleaner might be safe as it is designed for electrical contacts and plastic. Then again, it might not be.
05-27-2012, 03:55 PM   #3
I'd second contact cleaner, sorted my kx right out after it had redbull spilt on it. Some have oil in them, so make sure you get the 'dry' or 'no residue' type.
05-27-2012, 04:39 PM   #4
aleonx3's Avatar
Sometimes the hot sticky stuff come from a little spill of coke or soft drink that you may not even know... a damp cloth using clean water to clean the k-x body around the ON/OFF switch should help.
05-27-2012, 09:17 PM   #5
Great, thanks from keeping me from making the mistake. I hadn't even thought of something like Cokes on a fingertip getting in there, but that's probably close to what's happened. I'll just keep trying to clean it (moist cloth getting a touch of moisture into the friction area) and hope I can work out whatever residue is in there, then a little contact cleaner later. I wish I could open the switch to clean it out, but I don't have anything near the industrial clean-room environment i would need.
On the another note, i'm glad i finally found a question to share that hadn't already been answered somewhere on the forums. Virtually every other question i've had is covered somewhere around here. It's just made me feel unusually predictable. ;-)
Cheers!
<k>
05-27-2012, 10:35 PM   #6
pacerr's Avatar
Take a wooden tooth pick and see how small a drop or WD-40 (or your choice of cleaner) you can put on a piece of paper.
Then apply the smallest drop to the switch.
Mind you, it's the technique I'm advocating here, not the cleaner/lubricant of your choice.
H2
05-27-2012, 11:08 PM   #7
philbaum's Avatar
QuoteOriginally posted by pacerr Quote
H2
Great idea (but don't use WD-40, it turns into a gummy substance)
05-29-2012, 07:42 AM   #8
QuoteOriginally posted by Spazticus Quote
Cheers!
<k>
It isn't THAT big of a project.
See my albums - K200D repair.
camera, dslr, lube, photography, plastic, switch, time
turn left turn right... err no jeffkrol General Talk 33 04-19-2012 09:19 AM
BBC: LSD 'helps alcoholics to give up drinking' jolepp General Talk 29 04-15-2012 05:03 PM
Pentax helps conservation in Kenya Clinton Pentax News and Rumors 3 07-27-2011 01:33 AM
Lens lube Hiroshi Pentax SLR Lens Discussion 3 12-20-2009 02:37 PM
Should I use Lube ? vk4akp Troubleshooting and Beginner Help 17 05-07-2009 09:15 AM
All times are GMT -7. The time now is 11:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
