05-31-2012, 05:34 PM   #1
Pentax K100D Firmware....+
Hello all, I have just bought a K100D outfit, I love it already!! I have a couple of questions for you;
1) Can I still get the Firmware upgrade (I currently have v1.00); and, apart from the sdhc recognition, what do I get "for my money"?
2) I've had a Ricoh film camera for years, and have a good set of K mount lenses (Ricoh/Carl Zeiss/Prinz etc...),. which I'd really like to use. However, I believe that there is a risk of "lens lock on" with some older lenses, is there an obvious way that I can see if a particular lens is going to do that? As I also understand that removal of the lens from the body can be extremely expensive............which I would rather avoid!
Any help/advice will be gratefully received, thank you.
Dave.
05-31-2012, 05:55 PM   #2
boriscleto's Avatar
Firmware...
Software Downloads : Support & Service | PENTAX RICOH IMAGING
'Ricoh' Pin
The pin that will get stuck looks like a pin. Most 'Ricoh' pin lenses have a rounded nub that won't get stuck. The first pic also show another potential problem, the 'Vivitar' aperture shield. The 'Vivitar' aperture shield hits the power zoom/SDM contacts. I'm not sure if the K100D has those.
05-31-2012, 05:56 PM   #3
selar's Avatar
Firmware:
I am not going to post any detailed instructions, because I am sure atleast 5 other Pentaxians will come along and make more and more elaborate replies!
Beware of Ricoh Pin: https://www.pentaxforums.com/forums/pentax-beginners-corner-q/62194-ricoh-pin...ed-remove.html
05-31-2012, 05:57 PM   #4
selar's Avatar
Damn! Boris types faster than me!
06-01-2012, 03:13 AM   #5
Gentlemen, thank you very much; I now feel confident enough to use the lenses; As I said, I only just upgraded to my K100d DSLR, so I am cramming for as much info' as I can get, whilst "snapping away" like a good 'un!!
So, until the next time.................many thanks to you both!!
PS: I forgot; apart from the SDHC recognition, what else does the firware upgrade provide? Is it worth the time and effort (not that it's that much, but I just wondered, as I'm happily using it as it is!)
06-01-2012, 04:05 AM   #6
selar's Avatar
Changes to V1.02
  • Addition of compatible SDHC Memory card
Changes to V1.01
  • Support for SDHC Memory cards.
    * The focal length which is input on the [Shake Reduction] menu can be displayed with Pentax Photo Browser3.
06-01-2012, 05:43 AM   #7
Thanks for that, I guess the focal length capability will be useful if and when I use the older lenses? In which case I guess it won't hurt;
Thanks again for all your help!
Cheers, Dave.
06-08-2012, 06:35 AM   #8
Update:
Just so you guy's know, you're help and advice was not in vain; I am now running the upgraded software and I've had a real result with the old lenses from my Ricoh days........they all work and not a pin in sight!
So, many thanks again, for all your help,
Regards, Dave.
camera, dslr, k100d, lens, lenses, pentax k100d, photography
K100D firmware update vics587 Troubleshooting and Beginner Help 62 01-14-2021 05:14 AM
K100D firmware update - now won't power up bjcwheeler Pentax DSLR Discussion 6 04-26-2012 04:10 PM
Trying to upgrade firmware on pentax k100D Lisad620 Pentax DSLR Discussion 9 03-31-2010 10:29 AM
K100D Firmware anomaly Pentax DSLR Discussion 17 09-04-2007 07:32 AM
K100D firmware V 1.02 Bostjan Pentax DSLR Discussion 4 05-21-2007 12:57 AM
All times are GMT -7. The time now is 12:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
