Originally posted by Historicity I have a K20d and it has always worked flawlessly. The K20d is often mentioned on this forum and yours is the first negative I've seen. Before you smash it to smithereens, try the reset function. Return it to the factory settings and see what that does. I have a number of cameras and occasionally will set something wrong by accident and if I can't immediately figure out what I did wrong the "reset" solves my problem.
I always use the Manual mode and have never had the ISO on any of my cameras show up as anything other than what I set it to be.
If your camera is truly defective I suspect the problem lies in the software. I have had an internal chip go bad on an ancient Olympus E-1, and if I get a a lot of shutter actuations on my K20d something will eventually wear out and it might be a chip. It's a machine; something in it will always wear out.
Lawrence
IMO, OP is not looking for help, just looking for an excuse to rubbish Pentax, because OP made a beginner error and OP's pride has taken a bashing. Let OP break up the K20, probably doesn't know how to use it properly yet anyway. Unless it was all made up, read some of OP's other thread starts and see if you can detect the foul smell. YMMV
