Originally posted by miltona580 I have tried the fluorescent WB setting, and it seems to make colors odd, likely an artifact of my daylight CFLs.
You may try the tungsten wb setting then. My CFL in the living room is much closer to tungsten light, so selecting tungsten wb gives correct result (and fluorescent gives funky colors).
Page 185 of the K-x manual describes how to set custom manual wb with a gray card (or any neutral gray or pure white surface). You select the manual wb in the menu, point the cam on the gray card, press the shutter, then you can mark the card on the LCD and press OK. You can further fine tune it if needed.
