Originally posted by normhead But if you assume that an APS-c sensor is somehow different than an FF sensor, instead of just smaller... you might have a problem. SImple fact... same pixel pitch, same lens, same distance from subject... same I Q.
And different image, unless you crop the FF image to the same FOV, in which case it would be the 'same' image with the same IQ (if you kept the pixel pitch and sensor QE the same.)
Put a different focal length on the FF body, though, one that brings the same FOV from the same position, and things can change quite a bit with regard to IQ. Of course I've tried to explain this to you dozens of times, and it's never stuck, so I don't know why I'm bothering now other than I have a spare moment and I'm bored.
Quote: " "... if you start with a faulty premise it's hard to explain it simply.
Oh, it's not a faulty premise, Norm. However I've found that if you try to explain something like this to someone who refuses to acknowledge simple points about equivalence, everything and anything can be 'faulty' in their eyes.
