Originally posted by eddie1960 There is no reason to think that dropping FF sensors won't eclipse the apsc in over $1000 cameras within a couple of generations now that we are supposedly going to see mass production FF sub $2000 from the big 3. Pentax will be there.as well, or they will be selling to entry entry mid clients only and be marginalized even further in the higher profit realm
There are two fundamental problems here. One is the assumtion that most people actually want FF. There are no reason to buy an FF camera with its disadvantages if APS give give quality you want. There are no reason to assume that consumer think APS stinks imagewise or that they even consider FF as an upgrade path in significant numbers. You also have to take into account that Pentax have sold APS lenses for close to a decade now.
The second problem is that cheap FF camera won't be in a high profit realm. Cheap price means low profit*. Whats more, cheaper FF sensors means even cheaper smaller sensors that incidentally selling in enormeously larger quantities. That mean that the profit and developing cost on FF sensors needs to be covered by fewer units which increase price even further from the significantly increased manufacturing cost; thats why FF sensors are one to two generations behind APS sensors and MF sensors even more so. Theres nothing magical about the 35mm format. It is a relic from the film days.
Bigger viewfinder and better image quality is its advantage but it comes at a high cost. And remeber that you probably won't see a difference between an image shot with a K-5 and a 24mp FF camera even in a large print. Not to mention the difference between an 24mp APS camera and a 24mp FF camera a generation behind...
* Actually, if FF cameras experience price pressure and reduced profitability it would probably mean even more resorces into high end APS cameras as the sensor do not occupy such a large part of the cost of the camera. Hence, manufacturers will load those cameras with even more goodies to justify a higher price apart from the sensor thereby increase profitability.
