Originally posted by asgr Hi All,
I think this is the right place to post, but please move if not.
Recently the rubber grip has started separating from the main body around the front control wheel of my K7. The vast majority of the rubber is still firmly attached, but now when I scroll I tend to catch the edge and the rubber in the top moulded section appears to be loosely connected to body. This has been a slight issue for a while, but has become more pronounced now that I'm using my new 60-250- the extra pressure created when holding the camera has obviously forced the rubber off the body.
Has anybody else has similar trouble? Is the best fix just to poke down some superglue?
Thanks,
Aaron
FYI, the grip sections on the
K-7/K-5/
K-01 are completely stuck on with double sided tape. I think just adding some thin pieces of tape might help without making it permanent. If the camera ever needs servicing, using glue could be an issue because one of the grip sections needs to be removed to access some parts of the camera (screws under the grip material).
