07-10-2012, 10:40 AM   #1
k7 focus point indicators are gone
so my camera hit the ground hard and now my focus point indicators are gone, or more specifically some are gone, but the ones around the center are gone, and those are the ones i use. its not a big deal. but do anybody know if there is a fix for this or do i just have to bite the dust and bring it in to a vendor for fixing
07-10-2012, 10:52 AM   #2
slip's Avatar
QuoteOriginally posted by indeo Quote
First, reset all the camera setting to default
I would take the battery out overnight and see if it resets it's self. If that doesn't do it, try re-installing the firmware.
hope you fix it,
randy
07-10-2012, 10:52 AM   #3
LeDave's Avatar
You maybe have it set up to center point focusing, try changing the switch or through the menu (depending on your camera body) to do multiple point focusing.
07-10-2012, 11:04 AM   #4
im sorry i should have written this, i know they dont because when using select focus point the three center points dont light up i viewfinder but the others do
07-13-2012, 08:17 AM   #5
Not sure about in the K-7 menu but in the K-5 under the Custom menu 2 the bottom option, #14, Superimpose AF Area can be switched on or off. It sounds like it was accidentally turned off for you somehow.
07-14-2012, 03:22 AM   #6
As TomTextura says, the AF point indicators have probably just been turned off in the menu.
But if the superimposed AF points stuff is broken,, then maybe learn to live without visible focus points in the viewfinder? As long as your AF still works, you may not be missing much.
After all, the K-x doesn't have any visible focus points, yet it still works fine as a camera.
07-15-2012, 03:05 PM   #7
QuoteOriginally posted by TomTextura Quote
to quote myself. the post right over yours "using select focus point the three center points dont light up i viewfinder but the others do"
i have lived with it for some time, but thought i might just ask around here if by chance i F... up.
btw superimpose on k7 is on C #15. its on.
07-15-2012, 03:15 PM   #8
I wasn't sure that ruled out the possibility of having the AF points turned off.
What a strange problem. I guess you might have to send it in for service or just keep living with it. Either way, it's a bummer.
07-15-2012, 03:26 PM   #9
wizofoz's Avatar
A simmilar but opposite thing happened to my K-7. I have the outer focus points, but have lost the central indicators. I too dropped the camera some time before this phenomena became apparant. I only use the K-7 as a back up body these days, (and thats a rare event recently) so I just learned to live with it. I guess I should send it in for repair.....
I wrote about my experienes at the time https://www.pentaxforums.com/forums/pentax-dslr-discussion/106285-strange-cas...us-points.html
camera, dslr, focus, focus point indicators, indicators, photography
Focus point off center..by this far..any one else? suncrimson Pentax K-5 & K-5 II 23 01-05-2012 03:23 PM
bummed by lack of focus indicators with Kx Genshu Pentax DSLR Discussion 29 09-30-2011 10:03 PM
Setting the focus point Franky2step Pentax K-5 & K-5 II 11 09-08-2011 11:18 AM
Manual Focus and Link AF Point yusuf Pentax DSLR Discussion 5 08-24-2010 11:56 AM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
All times are GMT -7. The time now is 07:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
