So I'm mucking around w/ trying to do a flipbook and from multiple reviews, the K20D can supposedly sustain 2.3 FPS until the card fills up.
I'm using the fastest SD card (not SDXC since that's now supported) I know of (the Sandisk Extreme III before they neutered it and made it slower and cheaper) and shooting in 6MP JPEG, but it still hits about 20 images and then slows down to less than 1 FPS.
I also have AF set to the rear button, so it's not focusing. And I'm on manual exposure at 1/180sec. And shake reduction is off. I can't figure out what else to set to get it to work as expected
The K10D supposedly did 3FPS until the card filled because it had a smaller sensor, and the K-5 (1.5FPS?) is slower than the K20D. Apparently the sensor density has a lot to do w/ frame rate because it seems to read the entire sensor instead of a subset of it.
Anyone ever try Continuous Lo shooting? Do you get more than 20 frames before is slows wayyyy down?
