07-20-2012, 03:22 AM   #1
Lens hood or polarizing filter?
Hi. Which one would you rather use - a lens hood or a polarizing filter. I am finding it almost impossible to use both on the same lens, so which one should I use on a bright sunny day? Your comments and suggestions will be much appreciated. Thanks in advance.
07-20-2012, 03:45 AM   #2
Bruce Clark's Avatar
I don't think it is an either/or decision. They each perform separate functions in quite different ways. A good lens hood should have a cut-out or some way to let you manipulate the CPL for best effect.
07-20-2012, 03:52 AM   #3
Sandy Hancock's Avatar
Hood always. Polariser when wanted (and still with a hood).
07-20-2012, 04:25 AM   #4
Thanks for your quick replies. I had wrongly assumed that they both performed the same function (i.e., as regards stray light). Learned something new today. Cheers.
07-20-2012, 04:38 AM   #5
kcobain1992's Avatar
Hood on top of filter, always. Makes it easier to turn, too.
07-20-2012, 05:58 AM   #6
some Pentax lenses have a removable hatch(?) that allows you to use a polarizer and turn it through the opening.....genius....definitely on the 50-135 & 60-250 hoods
07-20-2012, 06:30 AM   #7
Docrwm's Avatar
You can also put a screw on 3-stage rubber onto the CPL and by rotating the hood actually rotate the CPL. I find this works well for me under most circumstances. If you already have the bayonet hood with a cutout then that works too but I find it more fiddling to use myself plus you run the risk of loosing the cutout.
07-20-2012, 09:27 AM   #8
sb in ak's Avatar
Hood always; polarizer if the situation calls for it....and to me, it usually does if I'm outside.
07-20-2012, 04:12 PM   #9
QuoteOriginally posted by Franky2step Quote
The hoods for the DA*16-50, DA*55, DA*300 and even the DA55-300 have this as well.
07-20-2012, 04:34 PM   #10
mbukal's Avatar
+da 17-70/4 al + da 55-300/4/5,8 ed
07-21-2012, 01:13 PM   #11
Moderator PEG Judges
Kerrowdown's Avatar
+1 it's exactly what I do too.
07-22-2012, 06:13 AM   #12
+1 from me too, cause this is what I do, unless I am hoping to get some flare.
camera, dslr, hood, lens, lens hood, photography
Polarizing Filter for DA 12-24 The Kurly One Pentax SLR Lens Discussion 7 10-14-2011 10:02 PM
polarizing filter kevingun Pentax Camera and Field Accessories 4 07-07-2011 12:03 PM
Flash with polarizing filter freddykrueger Troubleshooting and Beginner Help 5 03-06-2011 03:26 PM
Polarizing Filter- using one ? lesmore49 Pentax SLR Lens Discussion 4 12-17-2010 12:21 PM
Polarizing Filter Recommendation for 45mm lens. Swift1 Pentax Medium Format 9 11-30-2009 03:21 PM
All times are GMT -7. The time now is 03:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
