Originally posted by StephenHampshire My Sigma 30mm F1.4 is a pain to focus on the K5! This lens is renowned for high field curvature, although it has some very good points too. I do however find the SR mechanism on the K5 less prone to "wobbly focus" than the K20. With the later, I would often get one shot in the middle of a series of 5 or 6 shots suddenly OOF!
The K5 also seems to struggle in low, mixed light, i.e tungsten, low daylight etc. Seems better indoors in just tungsten/flourescent
The Sigma 30 is very sharp in the center but really soft along the edges. I'm not sure how large the sweet spot is but it seems to me that trying to focus any lens with the outer AF points where that lens is soft will hardly work anyway. Nikon people are saying that they are having issues with the outer AF points on the D800 with wide angle lenses (24mm), although I am at a loss to explain why a WA would work differently than a 'standard' or tele lens in this regard. The possibility of the lens being softer out toward the edges (thus confusing the AF system) seems a real consideration to me.
Faster lenses are going to work better in low light for AF and MF too. If the image going to the sensors is brighter due to the faster lenses it seems probable that AF will work better in low light with a faster lens attached doesn't it? Obviously an F/1.4 lens in low light is going to have a brighter image to work with than an F/4 lens (or even F/2.8) so before blaming the camera it might be an idea to think about which lenses are doing this the most.
I have never had any dramas with my K-5 in low light and it doesn't seem to be any worse than my D800E in that regard.
PS: The K-5 AF system is not meant to be used with lenses slower than F4 when a Teleconverter is a attached so it's easy to imagine a F4 zoom not really working well in dim light by itself.
