Originally posted by trog100
yes its horses for courses..
somewhere thow within the overall range of a zoom lens lies the quality of a prime.. the problem with zooms is they get reviewed over all their entire focal lengths.. people perhaps expect too much from them..
the tamron 18 x 200 at around 50mm is hard to tell apart from my pentax 50mm old manual prime without extreme pixel peeping..
Hard to believe. Pentax 50mm f:1.4 a@ f:5.6 is same as 18-200mm at 50mm wide open? (wide open at 50mm is ~4.0-5.6?) or both at f:8? I do not think so.
If you compare them both wide open, you compare apples to oranges because picture which is just possible with 50mm wide open may be 3-4 EV underexposed with Tamron.....
And basically aperture is used for adjusting DOF...... thus they should be compered at same aperture too.
and however much of a perfectionist u/we are "good enough" must be the order of the day else we would all still be useing medium or large format cameras and 35mm would not exist let alone our cropped digital versions..
I decide what is good enough according the most demanding end use of pictures. Most of my pictures dont need the extreme quality of primes, but I cannot be sure which one of them will.
If you use your pictures in net (downsized), or print them to max A5 cards and nothing else, you maybe dont need good (read: expensive) zooms or primes. End use is all.
i too like the quality of primes.. but for the very same reason i dont use a medium format digital camera i dont use a bag full of expensive primes..
My "expensive" primes has not yet exceed the price of two good wide aperture zooms at same focal length area :-)
FA 28mm f:2.8, FA 35mm f:2, FA 50mm f.1.4, Tamron 90mm f:2.5 SP, FA 135mm f:2.8, Tamron 180mm f:2.5 SP.
i do own the odd decent prime so i know the quality differences.. i also know they aint what they are mostly claimed to be.. and just like u i can find fault with any lens.. all u have to do is look close enough..
Maybe there is not such a beast existing than a perfect lens :-)
or maybe is, it depends on point of view. My perfect lens is maybe not perfect for you.
where convenience and pracaticality take over from the search for perfection i dont know.. he he.. but i do know that at some point it has to..
trog
It depends... everybody has to decide it themselves. I have been using even MF (645) equipments for a while. Trade out was too much for me and changed back to 35mm.
ps.. and your sign off thingy does kinda jar with your general comment.. the other day i read "a box with a pinhole in it takes pictures" but it lost its point coming from someone who uses an expensive dslr and all the paraphernalia that goes with it.. mind u it was in the dpreview pentax forum.. he he
Well, I have to say that I do not completely agree. :-)
May I explain: You do not take better pictures with more advanced and expensive equipment. They do not make you better photog.
But you shoudnt either use less capable equipment than you need for those pictures you want to take, taking into account their end use. You are not rewarded in this life or after because of the use of less capable gear in your work or hobby than you actually need.
If you need sharp lenses and 10 meg body because your pictures will be enlarged A3+ sizes, you should use them. But this sharp lens or 10meg body dont make you a bit better photographer. :-)
If you dont need expensive gear because the end use of your pictures is net or postcards, maybe it is not a good idea to buy them. Basic ones does the job as well. And you can spend rest your moneys for photosafari. Weak point in this is that you dont look like a pro....;-)
