Originally posted by jmarkku If you're into events/weddings photography your kit seems ok. Any additional body (like a secondary Kx) will do just fine, don't overdo it with the newest ones (unless you have the extra cash).
In my opinion you need two zoom lenses, preferrably on two bodies, to have the flexibility needed in changing situations such as weddings and events. One zoom for wide angle, another for tele shoots.
Agreed.
I usually say to get the lenses first. But if you're getting more serious about doing weddings and events, you must get a second body before your next one. Since it's a one-time event, you have to have a backup in case one breaks. You can actually get sued if you don't.
jmarkku is right - put a different lens on each camera, and use them both - for example, two different zooms, or one prime and one zoom. Then assume you drop one and break both the camera and lens (it really happens, and far too often). Make sure you still have a camera and lens that will get you through the rest of the event. As long as you always have your 3 zooms with you, you'll be covered.
You should take one or two classes on wedding photography. They usually cover both this and the need for insurance, as well as many other great tips.
Don't fuss about which body you get - another K-x will be fine. Remember that bodies depreciate, but lenses generally do not - especially if you buy used. Once you've got a second body, make sure you have a proper flash system. Then worry about upgrades.
