02-16-2008, 01:44 PM   #16
QuoteOriginally posted by jimgar Quote
I found out about the cap in this thread:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/13678-cheap-white-balance-cap.html
It's still out there on ebay for $5 shipping included.
Thanks. 20 items found here
02-17-2008, 10:15 PM   #17
Levi's Avatar
For really mixed lighting there's precious little you can do to get a "perfect shot"
here's what I do:
Recently I was at the St louis auto show, and in the Edward Jones dome the lighting is horrible, if you look up at the celing you can see that there's a random mix of Highpressure sodium (very yellow) and halogen (my guess) it's very white.
I shoot raw, and let the camera use auto white balance.
When I "develop" the pictures in ACR I have 2 controlls :color temperature I use to get close, and then color tint to take out any residual color cast. It takes a little work, the more you do it the better you get.
As best as I can figgure I'm correcting for the "dominant" light source with with the color temp. adjustment, and color tint corrects for the temperature of the "nuisance" light sources.
02-18-2008, 04:58 PM   #18
Levi, would you be able to do the same white balance correction with the Pentax software or Picasa? If it is, I'm sure its something I can figure out from the help file. I'm sure its a lot easier with ACR, but Photoshop is a bit beyond my current level.
Thanks in advance.
camera, cast, dslr, flash, light, option, photography, tungsten, wb
Front Focus and tungsten light question Big G Pentax DSLR Discussion 8 01-18-2010 12:25 PM
Can K20 be adjusted for indoor Tungsten light? philbaum Pentax DSLR Discussion 12 07-22-2009 05:40 AM
K100D Super Problem :( Amanda Pentax DSLR Discussion 3 10-27-2008 01:37 PM
K100D super problem jdg Pentax DSLR Discussion 2 04-21-2008 09:42 PM
Does the K10D and K100D Super fix the tungsten colour cast? snaggs Pentax DSLR Discussion 10 11-05-2007 02:51 AM
All times are GMT -7. The time now is 08:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
