Originally posted by sqjaw I know read the manual and I will , I am coming from a K-10-D to the K-7 are there any tips on using this baby
that you may have found when using it: Thanks a lot
There are some great features that the K-7 added over the K10D (and that I can remember now):
1) Bulb mode operation - you can now do it with two presses instead of press and hold
2) There's a level feature that tells you if the camera is level - should help avoid slanted horizons - this can be shown in the viewfinder or on the back LCD
3) The new Info button brings up a menu that shows you all camera settings - very helpful and well done - just navigate with the directional buttons and change whichever setting you want. If you press Info a second time, you'll get the nice level feature.
4) There's the in-camera HDR, but you need the camera on a tripod (JPG mode only)
5) The K-7 has extended DR settings - I usually keep them on all the time - they will bump min ISO to 200 if you set them both
The button layout changes are for the better. Once you get used to them, you'll find the K10D clumsy. The only bad change is the memory card door - it's harder to extract the card than on the K10D - just hold it by the edges and it will work - don't force anything.
Have fun - it's a well made camera and I think it is a historical Pentax model. They nailed an excellent control layout and a compact size with great handling.
